Local Time 05:00 12 Nov 2026 Privacy Policy
Forum Index : Windmills : Voltage Sensing Relays
old mate's mate
Posted: 05:48am 02 Jun 2011
Team, salutations, the windy season approaches, time to dust off the dust, etc ....
Has anyone had any experience with using a Voltage sensing relay as a dump load controller ? Something like this
cheers
OMM
powerednut
Posted: 06:35am 02 Jun 2011
$170 seems expensive for a dump load controller...
VK4AYQ
Posted: 06:48am 02 Jun 2011
Hi old mate
Try Glenn's dump load circuit on the projects page, it is a beauty and costs less than $20 to build
All the best
Foolin Around
old mate's mate
Posted: 11:23pm 02 Jun 2011
Yo powerednut and Bob, thanks for the prompt reply and for sharing your opinions regarding the cost of the relay. The voltage sensing relays were given to me (Over AND Under (Window) sensing, like the one in the link, and a couple that sense Over OR Under (dip switch selectable). Both relays can be configured to be Latching or Non Latching.
In this particular situation the cost is not a variable within the function so if I may ask again:
Has anyone out there had any experience with using a voltage sensing relay as a dump load controller ?
cheers
OMM
toxsickcity
Posted: 10:55pm 03 Jun 2011
http://jaycar.com.au/productView.asp?ID=KC5377&keywords=volt age+switch&form=KEYWORD
I've used this cirucit on 24v dc to power it by using an 7812 reg & heatsink,
I put a resistor large value, 1m ohm to scale the input down, allowing me more voltage range.
costs 30$ and works well..
I also use this circuit for solar battery (low voltage disconnect), adding a Capacitor/diode on the Input can give this circuit a 10-20seconds allowance in drop of voltage
IE: Momentary Large Loads.
cheers
Janne
Posted: 10:44am 05 Jun 2011
I haven't used them in dump load duty, but have succesfully utilized them as overvoltage protection for windmills.
They should work also as a dump load controller, they have all the specifications needed. Adjustable latching voltage, adjustable hysteresis.
The snag in them is the mechanical output contact. It the right conditions it will be swithcing quite often, so contact life could became a potential problem in this use. Best would be to use an SSR to switch the actual load, and just use the voltage relay for sensing and switching the main relay. With small currents the endurance would be limited only by the mechanical life.
On the other hand, as they're designed for industrial use, they're far more robust than a bodged electronics card.
If at first you don't succeed, try again.
My projects
