Local Time 01:44 12 Nov 2026 Privacy Policy
Forum Index : Windmills : Sclerosis anyone?
AllanS
Posted: 09:25am 07 Nov 2006
A little something here to help warm the shed. Wonder how she'd go with a bit of orange juice.
Hey, it's relevant. Alternate energy and all that.
Posted: 11:01am 07 Nov 2006
Very clever, and makes a lot of sense if your a farmer and handy with metal working. With the price of fuel these days.
Speaking of ethanol, I started running my 92 Commodore on the E10 blend about 1 year ago, and I swear by the stuff. The old V6 has done about 200,000km, and with the E10 its a lot crisper to drive, more get up and go.
AllanS
Posted: 11:41am 07 Nov 2006
I was thinking about this the other day. A hectare of cane gives you about 10 tonnes of dry sugar, or if sugar-beet in cooler climates, 7 tonnes. Ferment that and distill it. You'd get a fair bit of fuel, maybe 5 tonnes per Ha. It sounds good, but that's only $5000 worth. I reckon the opportunity costs and labour costs to the farmer would make it cheaper to fill up at the servo. A bit of a bummer.
Pt w/field Matt
Posted: 01:04pm 07 Nov 2006
johney and co wouldnt like that!!!
matt down south
RossW
Posted: 08:50pm 07 Nov 2006
  AllanS said   I was thinking about this the other day. A hectare of cane gives you about 10 tonnes of dry sugar, or if sugar-beet in cooler climates, 7 tonnes. Ferment that and distill it. You'd get a fair bit of fuel, maybe 5 tonnes per Ha. It sounds good, but that's only $5000 worth. I reckon the opportunity costs and labour costs to the farmer would make it cheaper to fill up at the servo. A bit of a bummer.
I agree that if you had a saleable crop you wouldn't do it. But in those times where your crop has been damaged by weather, or there is a glut and it costs you more to get it to market than they pay you, or it's been a fallow crop, then anything that can make a mash just might be worth it.
Unlike a "ripe" crop, ethanol will keep indeterminately in sealed containers, without refrigeration.
And if the farmer has damaged or unsaleable crop, it just might be better to make mash and ferment it, than dig a hole and bury it.
AllanS
Posted: 09:44pm 07 Nov 2006
The trick is to convert cellolose into ethanol. Enzymes or acid treatments hydrolyse the cellulose into glucose, and this is fermented. Advances have reduced enzyme costs from $1/litre to a couple of cents, and now they're engineering bugs that will do the cellulose-ethanol conversion in one step. This will be brilliant for farmers disposing crop wastes of all sorts. Municipal garbage could also go thru a digester, turning paper and green wastes into ethanol.
The thing we need now is a bit of water to grow these crops. We've got stacks of land, it's just not bloody raining. Desalination is pushing $1/m3 potable water to produce, and that cost's falling. At that price, could you grow a fuel crop (or any crop) profitably, using hydroponics or whatever?
