Local Time 05:00 12 Nov 2026 Privacy Policy
Forum Index : Windmills : Tips for starting off with F & P
shift540
Posted: 05:41am 13 May 2011
Hi all,
Im new to the game and would just like a few tips. Firstly i just got my hands on an old Fisher and Paykel smartdrive washing machine and removed the stator, and bits i need. My first problem was the shaft just didn't want to come out without force, so i had to use my trusty hammer. Problem here is im hot to sure if i damaged the shaft,and if i can get the cover to screw on far enough now. How low are these supposed to sit? I can see about 8mm of magnet (from stator when cover is on). Secondly when i set it all up in a vice and gave it a spin it makes a grinding noise like the magnets are rubbing, and there is a fare bit of resistance, is this normal? I also gave it a spin with the drill and i only seem to be getting 95 volts (haven't re wired it yet)I had a bit of a look on the net and most people seen to get a greater reading when doing this. my drill was flat out..
Anyway thats me for now, appreciate you reading and any advice would be great
Poss
Posted: 09:28am 13 May 2011
How have you got it set up ?? a picture would be good. Do some reading and keep your pinkies away from the 95 volts !
A brave man may not live for long, but a careful man does not live at all.
Posted: 05:25am 15 May 2011
Hi Shift540
One of our forum members Ross put together a page showing the correct way to pull apart a F&P Smartdrive. http://www.thebackshed.com/windmill/FPdiss.asp. It sounds like you have bent the shaft, they should come our easily with a little tap.
There should be no grinding noise, or binding, and the magnet hub should fill over the stator with no stator poles showing.
Have a look and see whats bend/broke. You might be able to fix, or find another.
Watch out for the AC volts when you spin with a drill, or even by hand. A F&P Smartdrive can easily kill you if your not careful, as Poss pointed out.
grub
Posted: 09:24pm 15 May 2011
If shift540 was driving the shaft out by hitting it on the threaded motor end, then he could have bent the threaded shaft. It could also be that he is now trying to fit the motor to the agitator end of the shaft.
Also, did you remove the bearing housing from the washing machine drum?
Comes in handy to mount the motor too.
GaryP
Posted: 11:23pm 01 Jun 2011
Hi Shift 540.
I just got my f and p and found the same thing. I had no resistance in extracting it from the washing machine.
I think you are probably just feeling the cogging.
I must admit that even with the magnet drum removed there is some mild resistance with just the bearing and the rubber washer at the other end. I removed the little retaining spring over the rubber which helped a little and oiled it.
I have a treadmill turbine which spins with much less resistance but can't make much power
The inherent resistance in spinning these F and Ps to me seems quite high and I reckon you need lots of tourque in light winds to get these going. I will certainly try decogging before setting it up.
$@#&*....the word often heard in my shed when it doesn't go to plan!
brucedownunder2
Posted: 03:43am 02 Jun 2011
Hi Crew , I'll be as kind as I can .....
Youse guys that are just starting into this F&P thing ...
PLEASE DO AT LEAST 2 HOURS READING ON THIS FORUM BACK POSTS BEFORE YOU EVEN LOOK AT YOUR TOOL BOX ....please,please.
Udder wise all the scrounging efforts you went to are in vain... Been there ,Done that..
OK,,lecture over ,, now the factory seal has to be discarded.. Clean everything up on removal with kero or whatever .. clean the bearings ,(99% are OK ) ,light sewing machine oil is ok..
NOW, GO BACK AND READ SOME MORE..LOL.
If you have a problem please post it here and I along with many others will try and steer you in the right direction -remember,, these gennies have taken thousands of hours within this forum to get it right --you are not going to get it right overnite...
OH,,, watch out for the VOLTS it's terminal ..trush me.
Bruce
Bushboy
