Local Time 01:33 12 Nov 2026 Privacy Policy
Forum Index : Windmills : Permits/consents??
tomasp
Posted: 02:53am 27 Oct 2006
Hi guys,
The situation might be a bit different in Australia than in New Zealand but nevertheless I want to ask how have you arected your towers? Say I plan on 20m guyed pipe tower in rural area, but someone told me I need resource+building consents for that ($2000+ if approved) - what is your experience? I guess people just go ahead and build them without permit as long as they have good neighbours?
Posted: 03:15am 27 Oct 2006
Thats a bit of a grey area. I'm lucky in that I live in a rural zone, and I can "self assess" any structure I put up. As a rule, I tend to over engineer my windmills and towers, build it heavy and strong. I would rather something that was too heavy than light and weak. And whenever I lower or raise the tower, I make sure no one is anywhere near it, including me ( I use a remote switch on the electric winch ).
In this day and age of no one taking responsibility for their own action, I should have the windmill tower fenced off, and signs to say "If you climb the tower and fall off, you may break something or die".
I believe in residential area's you first need to contact your local council to see if a tower is permitted, get in writting consent from your neighbours, and then get engineering certificates for the design. Its a real nightmare, which is why most people just ask their neighbours first and then just build the thing leaving the council out of the loop.
tomasp
Posted: 03:48am 27 Oct 2006
Glenn,
Thanks for the quick reply. I was digging throuth the documentation and found that for "network utilities" in a rural areas the tower is limited to 20m height. However a building permit is still required...Also just found that a resource consent is only needed if a turbine is 5kW+ - phew. Asked the council to confirm. Now I need to find out about building permits...
Worst case I guess just build it after asking neighbours - luckily they are nice and only one of them has grid power.
