Local Time 01:33 12 Nov 2026 Privacy Policy
Forum Index : Windmills : long vawts
2e0bax
Posted: 10:33pm 15 Oct 2006
Has anyone built or experimented with long multi vaned VAWTS? Im talking about about Stacking sets of vawt blades. I have a few ideas to try but feel if theres already some results i could skip some ideas? Looking foward to replys. Sean.
Posted: 03:28am 16 Oct 2006
No expierence myself, but there is one big advantage VAWTs have over HAWTS. To get more power from a HAWT, you need to go bigger in the diameter, and this reduces RPM. But to get more power from a VAWT you go higher, and this has no effect on RPM.
A tall VAWT will need supports evert few feet to keep it all in line, do a google search for vertical windmill's and look for the ones made from 44 gallon drums. I've see examples that are 4 or 5 drums high, and they have a frame work to provide a bearing between each drum.
AllanS
Posted: 03:56am 16 Oct 2006
What I'd like to see is a small, cheap VAWT atop every power pole in the country. The pole's already there looking ugly as sin. The means of distribution is right there. Wouldn't that crank out some power?
Some turbines look quite good too. See hereEdited by AllanS 2006-10-17
