Forum Index : Windmills : 5 Phase pma project
faroun
Posted: 03:35am 08 Nov 2010
here is few links to my 5 phase pma project.
youtube link 01
youtube link 02
regards
sam
Many Ideas One Brain.
http://www.wrapwind.com
Posted: 10:03am 21 Nov 2010
Thanks for posting Sam
Interesting project, let us know how it performs. The workmanship is very good, I like the coil winder.
faroun
Posted: 01:28pm 21 Nov 2010
here is the results, i compared 3 phase to the 5 phase:
3 phase:
1disc 10" 24magnets, n48, 1x.5x.5
18 coils, 18gauge, 100 turns, star connection, ladder rectifier (the one i built).
no load @ 165rpm =>13.5vdc
loaded using bulb, @ 235rpm =>13.5vdc
in total the tape drive consumed 42 watt
produced 12 watt included in this figure is 3.2watt for tape drive.
70rpm diffrence from loaded to unloaded due to resistance.
losses 30 watt.
5 Phase:
20 coils, 18gauge, 100 turns, star connection, ladder rectifier (the one i built).
no load @ 200rpm =>13.5vdc
loaded using bulb, @ 255rpm =>13.5vdc
in total the tape drive consumed 35 watt
produced 11.2 watt included in this figure is 3.2watt for tape drive.
55rpm diffrence from loaded to unloaded due to resistance.
losses 23.8 watt.
on another forum we came to the conclution that the resistance is 6.18ohms
and that is why the volts VS rpm changes.
do you feel that is correct?
thanks
sam
Posted: 01:31pm 22 Nov 2010
Hi Sam,
I think that some more electrical data would be of use.
To be of use, the loads should be varied and the power for the same rpm of each test would be a better comparison.
The higher cutin rpm alternator gives a higher efficiency. This will be clear considering the fewer total turns per phase, and effectively more in parallel, giving a lower resistance.
The losses still seem quite high, but I am unclear as to the total power output for the losses you have quoted..
Gordon.
faroun
Posted: 09:45pm 21 Dec 2010
3 phase VS 5 phase conclusion
bellow is an update to where i am at.
it havs been terrible with snow storms.
things are a bit slow. but moving ahead.
3phase:
1 disc, 24magnets, 10.25"
18coils, 125turns, 18awg, star config
free spinn= 100rpm=>13.5vdc
under 24vdc light bulb load=> 130rpm=13.5vdc
under 36vdc light bulb load=> 122rpm=13.5vdc
under 48vdc light bulb load=> 115rpm=13.5vdc
@45rpm=1.25amp shorted
5phase:
20coils, 100turns, 18awg, 5neutral config
free spinn= 155rpm=>13.5vdc
under 24vdc light bulb load=> 187rpm=13.5vdc
under 36vdc light bulb load=> 182rpm=13.5vdc
under 48vdc light bulb load=> 176rpm=13.5vdc
@85rpm=1.85amp shorted
regards
sam
Posted: 11:16pm 21 Dec 2010
More so you have less turns per phase and extra diode loss (1.2v) for the 5 phase compared to the 3 phase.
Pete.
faroun
Posted: 01:58am 22 Dec 2010
  Downwind said   More so you have less turns per phase and extra diode loss (1.2v) for the 5 phase compared to the 3 phase.
Pete.
Pete, i was hoping for better result on the 5phase , well all my projects are on youtube for others to see and learn from.
i cant wait to get the 3 phase hooked up on my vawt.
regards
sam
