Local Time 06:03 12 Nov 2026 Privacy Policy
Forum Index : Windmills : The Column 700w-3b-12f VAWT
     Page 1 of 3
faroun
Posted: 02:18am 31 Aug 2010
hi there guys, here is my latest turbine created. i have been having a great discussion about it on another great Forum. i figured lets see what you guys think!
it is a VAWT turbine that uses airfoil for a vawt blade.
created, designed and developed by sam chamas and prototype manufactured by farmenergyinc.ca
i am sure there are questions..lets see how it goes.
here is the youtube link...enjoy.
YOUTUBE LINK
regards
sam chamasEdited by faroun 2010-09-01
Many Ideas One Brain.
http://www.wrapwind.com
MacGyver
Posted: 03:07am 31 Aug 2010
faroun
That's a clever design. I'm curious why one turbine was spinning and the other was stopped. Does your VAWT self-start or do you have to give it a little push? Does the spinning one have more blades than the stopped one?
It'll be interesting to see what it does with a load. I should think widening the blades at the center, to give them more leverage on the axle, which will act as a "moment-arm" against any load, would be an advantage.
I'm eagerly awaiting more videos; thanks.
. . . . . Mac
Copeville, Texas
VK4AYQ
Posted: 03:22am 31 Aug 2010
Hi Sam
Looks like it has potential but needs to be built a lot stronger with more blade support. Im not sure what the noise is it sounds like the blades moving in the end plates.
I built a simular one thirty five years ago it was 2 foot diameter with three blades 8 inch cord, with symmetrical airfoil. I found that if I spiral twisted the blades 8 degrees top to bottom it ran smoother and a lot quieter. It used time expired helicopter blades from the local helio repair shop. The blades where held at four points with clamps with insertion rubber to damp our resonance.
I used a small sevouris rotor on the top to make it self starting.
All the best
Foolin Around
faroun
Posted: 12:13pm 31 Aug 2010
  MacGyver said   faroun
. . . . . Mac
they are 2 diffrent turbine layout, it was done like that for testing.
the successfull one if the Column-reverse and the other is the Column forward.
i do explain alll that in the other videos.
it self starts at 13kmh wind. but also i have added a savonius on top for it to start at 8 kmh wind. also i show how i did it in ohter videos.
they both have the same blades.
regards
sam
faroun
Posted: 12:34pm 31 Aug 2010
  VK4AYQ said   Hi Sam
All the best
My custom blade design is tapered and not rectangle shape, the tip is smaller than the base (mid point).
The blades are made from solid wood.
regards
Sam
faroun
Posted: 04:32pm 06 Sep 2010
hi guys, i did some calculations and the result was not so wow.. please review and see if i am correct or not..thanks
[size=150]P=½pAV³
P = power in watts
p= The air density (1.2kg/m³ @ sea level and 20° C)=1.2
A = The swept area of the turbine blades (m² square meters)=1.7m²
V = wind speed ( meters per second)
the VAWT is 12' tall wings and a 1.5' diameter arc, the swept area A=18 ft² = 1.7m²
Wind speed @ 15 mph = 6.7 m/sec
Wind speed @ 30 mph = 13.4 m/sec
Wind Power at 15 mph is: P=½(1.2)(1.7)(6.7)³ = 307 watts
Wind Power at 30 mph = P=½(1.2)(1.7)(13.4)³= 2454 watts
then we introduce the wind and alternator efficiencies factor: of Ct and Ca
[size=150]P=½pAV³CtCa
you could expect about 40% of 60% of the wind power
Wind Power at 15 mph is: P=½(1.2)(1.7)(6.7)³ (.40)(.60)= 74 watts
Wind Power at 30 mph = P=½(1.2)(1.7)(13.4)³(.40)(.60)= 589 watts
is the above numbers relestic?
note: i posted the exact info and request for feed back on other forums, just to see if i am not fooling myself.
remember that with this narrow design i loose tork but i gain rpm inertia.
thanks
sam
Posted: 07:03pm 06 Sep 2010
I like the design, but the simple fact you could friction brake it with a piece of wood onto a 1" shaft rings some alarm bells, to the behavior of it with a generator attached.
It would be nice to know the rpm it reached unloaded, as mills dont reflect a very close relationship of rpm to anemometer wind speed.
Watching with interest.
Pete.
faroun
Posted: 09:37pm 06 Sep 2010
  Downwind said   I like the design, but the simple fact you could friction brake it with a piece of wood onto a 1" shaft rings some alarm bells, to the behavior of it with a generator attached.
Pete.
pete, it was silly of me to let it spin wild like this, i should balance it first, then connect a gen that i am working on, and then let the sucker go, i am sure it will reach the 500 to 600 rpm but i wonder if it will stay together.
i am working on 9coils and 12 magnets axial flux,
i want no power drawn form it at 200rpm but bettween 200 and 600rpm is where the power is, and i know that the turbine reaches 200 rpm at 10kmh. So this turbine will not make anypower bellow 10kmh.
any thoughts on that?!?
regards
sam
Posted: 02:44am 07 Sep 2010
Hi Sam,
I would be doubtful if you will reach that high of rpm with a vawt and the speeds you are quoting are Hawt sort of speeds.
You watch the prop on your other mills (hawts) in a good wind and then see if you think the Vawt is keeping up with them, i dont think it would be possible.
I think you will need to aim for around half that cutin speed, and then torque could be a problem.
It will still be interesting to see what you get out of it.
Pete.
Posted: 11:42am 07 Sep 2010
Hi Sam
It's a neat little windmill. Just going over your calculations and I can see a problem. Your using swept area to work out how much power there is avaiable from the wind, but that only applies for a HAWT with a turbine facing the wind. Its different for a VAWT like yours. Your wind area is 3.657m high by .457m in the middle. But what we dont know is the diameter at top and bottom. Once you know that, you can work out its area thats facing the wind, at a guess somthing like 1.2m2.
Pete's right about the lower RPM for a VAWT, but looking at the video I think you have a reasonable RPM, thanks to its small diameter. If you can get it taller you will gain power while keeping the high RPM.
faroun
Posted: 02:44pm 07 Sep 2010
  Gizmo said   Hi Sam
the turbine is
top:mid:bottom
15:30:15 inside of ring
20:40:20 outside of ring
and the blades are 76" x2 =144" high
note that i am tlaking the Column-R is the winner, not the Column-F.
regards
sam
faroun
Posted: 02:42pm 08 Sep 2010
Also the turbine is 145lbs. made form solid wood. i am not sure how to add the wieght+rpm into the equation. i am sure that there is a diffrence bettween a light and heavy turbine, but not sure where to apply this mass advantage!? any thoughts?
thanks
sam
VK4AYQ
Posted: 06:35am 09 Sep 2010
Hi Sam
The rotational mass wont make any difference to the power absorbed from the wind but will give you a bit more inertia, so it will store a little bit of energy like a flywheel and smooth out the gusts a bit.
All the best
Foolin Around
itsandbits1
Posted: 05:52am 12 Sep 2010
  Downwind said   Hi Sam,
the lift type vawts that are being made are easily able to achieve above 200 rpms. if you watch his vids you will see 200+ I realize that a hawt does well over this but a vawt has much more torque at these rpms and the pma can be designed for this area which would stall other units. Not saying one is better than the other except that I find it a lot easier to get power from a vawt but am also playing in the hawt sandbox
faroun
Posted: 01:02pm 12 Sep 2010
i have slowed things down at this time, in order to show that it can reach high rpm, i have to balance it first, so i am hoping in the next few weeks i will achieve the balancing goal.
i am also increasing the the size to top:mid:bottom = 22":42":22" by doing that i will drop the rpm to 500rpm produced at 30mph= 515watts
A typical wind turbine efficiency (Ct) is about 40%, and alternator efficiencies (Ca) are about 60% efficient*. These numbers will vary depending on the designs
P=½pAV³CtCa
A = The swept area of the turbine blades facing the wind (m² square meters)
= 22"+42"=64"/2=32"x144"=4608"=2.97m² facing the wind, that is for the hawt. lets say that my vawt blades most effecient at 50% facing the wind,
in this case A=1.485m²
V = wind speed ( meters per second)=13.4m/s
P=½(1.2)(1.485)(13.4)³(.40)(.60)= 515 watts
i will be happy with the results above, because my structure can hold 2 or 3 of these turbine in the same area.
regards
sam
faroun
Posted: 08:26pm 10 Oct 2010
hi guys, here is where i am at. i increased the diameter of one and adjusted both to be Column R.
You tube video
regards
sam
fillm
Posted: 10:37pm 10 Oct 2010
Hi Faroun,
Just as a matter of intrest , what airfoil are you using ?
faroun
Posted: 11:43pm 10 Oct 2010
  fillm said   Hi Faroun,
i am using my own modified airfoil, based on knowledge from my work experience.
regards
sam
faroun
Posted: 10:38pm 15 Oct 2010
I am very..very disappointed for not able to build it correctly. I feel I am stuck, I cant go forward until I can build the vawt and balance it right.
It is disappointing when I tried to avoid all these problems by cutting the disks on the cnc and took my time and measured many times before I put it together.
So all I got is the following:
3.2m/s I got 200rpm
4.5m/s I got 320rpm (and as you can see in the video, I did not let it spin to its fullest, but that is all I got for now)
All I can say, that based on the bit of info that I have, I can see the turbine making the 500rpm at 6 to 7m/s and that is the only thing that is keeping me happy.
For some of you, I think you were waiting for an awesome finish, but sorry to let you down, I need to figure a way to build it right.
youtube video
regards
MacGyver
Posted: 02:02am 16 Oct 2010
faroun
Chin up, mate; join the club. That's about 90% of what this is all about. Look at my signature line, "Nothing difficult is ever easy." Those immortal words are from Bullwinkle Moose. To add a little more posture, I quoted Morgan Freeman saying something similar.
Your balance problem may very well be something as simple as a variation in the density of the plywood (?) you've used as your center spreader plate. I noticed there are some speeds that seemingly are not affected by imbalance and that's why I think it's something simple like this.
Since you show yourself using a "board brake" on the main shaft by leveraging a piece of wood against it as it rotates, I'll assume the existing center circle is attached to the main shaft solidly and if that's the case, it seems to me it wouldn't be much work to cut it out and replace it with three symmetrical-section wing-shaped spars all the same weight. If the problem is in that center circle, doing this would both lighten the build as rid you of the imbalance.
Don't worry about losing any "flywheel effect" by lessening the weight. What you gain in momentum, you lose in overcoming it at start-up; it's a wash. The genius of the VAWT is its simplicity and high(er) torque in low-speed winds.
If I were building a VAWT (someone slap me!) I'd be shooting for two or three huge paddles in the wind and use a transmission (V-belt most likely) to change the raw torque into speed. For those purists that can't bear to see the word transmission, I'd maybe design a rather large axial-flux rig that would reach cut-in at somewhere around 90 rpm.
Everything (well almost everything) is possible. You merely have to take it one item at a time and march on. You're lightyears ahead of most; don't give up the ship just yet. One small change could spell success.
. . . . . Mac
Copeville, Texas
     Page 1 of 3
