Forum Index : Windmills : Hubs for PVC and Ali Blades
old mate's mate
Posted: 06:45am 19 Aug 2010
Fellow enthusiasts, greetings .....
I have just priced getting some F&P hubs for the extruded blades laser cut as per the dxf on this site. A single set (at 6mm) * 5 components was quoted at approx $160.00. If I order 10 of each economies of scale kick in and they are cheaper.
I can't use 10 sets, would anybody else be interested in a set at around $75.00 plus postage ?
If there is enough interest I will organise the work and postage. Please reply if interested. If I proceed with the order it should take about 2 weeks to deliver to you.
PS I tried getting them cut with a plasma cutter but it looks like the concentrated heat while cutting the splines ruined the job, has anybody else had a similar experience ? As with everything there a probably a few flavours of plasma cutters out there ......
all good (7 phase 3*2C rewire of the F&P successful !!)
OMM
