Forum Index : Windmills : FANUC SERVO MOTOR HELP NEEDED
isaiah
Posted: 02:50am 15 Aug 2010
Bub's has a fanuc servo motor with a tapered shaft and wants me to turn it straight!
can this be done by taking the armature out of the motor and put it ni the lathe and turn a section of the shaft straight to fit a hub for wind mill blades without the magnets going dead??
I understand if you were to take the armature and turn it at hi rpm's in the lathe the magnets may become dislocated.
Dose any one have any input on this ?
Dose anybody know what thread and pitch is on the shaft it looks to be 12 mm something fine?
any help will be appreciated.
