Local Time 06:43 12 Nov 2026 Privacy Policy
Forum Index : Windmills : how do I regulate my smart drive
junknerd
Posted: 07:41am 17 Jun 2010
just so google finds it ..
How to regulate a Fisher & Paykel smart drive
how is the most efficient way to regulate a f&p smart drive?
Iv bult a smart drive wind turbine and have tryed regulating the voltage with a universal electronic power supply (110-240v ac to 12v dc) and it works realy well at high speeds it even workes on DC!
is this the most efficient way to do it? and i want to charge a 48v battery bank can i change the out put of a switchmode power supply easly?
prove all thing hold fast to that which is true
VK4AYQ
Posted: 07:46am 17 Jun 2010
Hi Junkee
Can you give us some more details as to what you are doing with the FP it sounds from the voltage you quote that you are running it without reconfiguring the windings.
All the best
Foolin Around
junknerd
Posted: 06:39am 18 Jun 2010
yes iv left the smartdrive in it original condition i had a windwill and now im trying to buld a pelton weel
for my pelton weel iv got a 1/6 gearbox attached and its a early modle smartdrive
Posted: 01:00pm 18 Jun 2010
Hi junknerd,
Welcome to the forum.
As many do you are going about this backwards.
You are generating a high voltage at low amps and then converting this to lower voltage at higher amps.
Simply you loose at every step of the way, and results in a output less than input.
What is done, is to reconfigure the stator coil windings to better suit the voltage range needed and giving higher amperage output for rpm.
Have a look on the front page to the web site for a link to F&P.
Pete.
KarlJ
Posted: 12:33pm 19 Jun 2010
couldn't have said it better myself
thanks Pete
junknerd
Posted: 05:11am 21 Jun 2010
Thanks guys
I realise that with any conversion u lose power but my battery shed is about 400m away from my weel and there is already a 3core 6mm cable buryed under ground
and im scared of the voltage drop sorry i didnt include this when i started
yes i have seen the rewire methods, what would work better star or delta?
and can i wire it so it puts out single phase?
