Local Time 07:17 12 Nov 2026 Privacy Policy
Forum Index : Windmills : Are Motorwind just a gimmick
littlebuddha4
Posted: 09:05pm 08 Mar 2010
hi all i been looking at wind power for some time and over the last year i been looking at a site called Motorwind http://www.motorwavegroup.com/new/motorwind/index.html now i have had one of you guys looking at it saying it just a "looks like a gimmick" love some of you guy to look over the site and tell me what you think . I only got one lot of $ to spend on wind power and solar as i am a pensioner so i have to get it right the first time. you comment i love to hear
thanking you for yr help
Paul & kerrie
ever days a good day
Perry
Posted: 09:36pm 08 Mar 2010
Hello,
I didn't spend much time looking through the site but I did see something on TV about them. I put it into the gimmick category. I imagine hundreds of cheap plastic gears would make quite a howling clacking noise.
The gen is only rated for 2.8 amps so if you run it into a 12V battery the most you can hope to see is about 35 watts. Can't do much with that.
If you are truly cash strapped and want to get the most from your money I would recommend solar.
Perry
neil0mac
Posted: 10:25pm 08 Mar 2010
  littlebuddha4 said   saying it just a "looks like a gimmick"
A gimmick? Possibly not. Quirky, Yes!
But then a wind system (the 11 turbines with water pump)that can pump from 150 metres down must be able to generate some serious amount of energy?
Suggest you give some estimate of power needs to get meaningful responses.
Do you want it on or off grid generation?Edited by neil0mac 2010-03-10
KarlJ
Posted: 10:33am 09 Mar 2010
i like it but I think realistically you need the 2000 mini fan model!!!
seriously it is a good idea but i dont think its really capable, one of those things you need to see to believe
Karl
Posted: 12:34pm 09 Mar 2010
I feel they have their place and far from a gimmick.
They are not in the same field as a pole mounted wind turbine.
We often get people here wanting to build a mill to take camping and these gadgets would suit the application well.
I think they would also work quite well in turbulent air where a standard mill wont.
They would also look neat in council parks for lighting along with the other crazy plaground equipment and art expressions.
Just maybe not a back yard full of them.
Pete.
