Local Time 07:17 12 Nov 2026 Privacy Policy
Forum Index : Windmills : Can we beat commercial 2kw mill?
KarlJ
Posted: 09:54am 25 Feb 2010
It has come to my attention that you can buy a 2KW+ chinese turbine of various brands from $1500-$3000.
Question is realistically can we beat even $3000 for a mill good for 2.5KW in 10m/s good for a max output of 3.6KW
for that money?
I'm thinking its very tough to beat when the neo's alone are $700 or so, even if labour is free, all the bits and pieces add up quickly.
Posted: 10:40am 25 Feb 2010
I would think the neos would be under half that Karl.
Its a matter of if you like the fun of building something and watching it all work out and being able to say ...i done that.
I do agree it is tempting to work out of the box but you dont learn much that way and this great forum would not have got off the ground if everyone went that way.
Pete.
Perry
Posted: 11:05am 25 Feb 2010
I think it is increasingly hard to meet that price point. The Chinese are getting better and better at WTG design due to their heavy government funding in this area plus their labor is 1/4 what I spent in beer making mine.
Perry
KarlJ
Posted: 07:53am 26 Feb 2010
best i've found for 2" x 1/2" round neos is $30 each
x 24 = $720.....
starting to look like obviously they can buy bits cheaper than us to the point where its getting very tough to beat.
and as you point out beer is also expensive, i reckon i've spent $1000's on that alone!
Bryan1
Posted: 09:13am 26 Feb 2010
Well lets see if 168 off 16x13mm N50 round neo's can do that quote that the thread is based on. Those mags will be placed to emulate a 48x13mm round neo. Using 2 in hand 1.6mm wire should get the stator down to under 0.5ohm and on a 24 volt array using a self made 4 metre diameter prop those figures will be realistic.
True the price and quality of those Exmork Wind Gennies are hard to beat the DIY aspect is taken away. Those 16mm neo's only cost around $250 landed and as I can make the rest on the cheap I will document the costing on my turbine and see if I can make the above claim....
KarlJ
Posted: 12:02pm 26 Feb 2010
I think Phill ran into this demon too.
When I got a quote for his turbine, he hadnt really priced all the bits to the nth degree, when he did he realised he had pretty much done lots of work for very little.
That said -making something from nothing and then having something good enough to sell is a Fantastic achievement way beyond concocting something no-one is prepared to buy.
I have my fingers crossed that Phill will sell me the AX300 when the 400 is finished as he only has two towers
If you're reading this Phill I want first dibs on the AX300!
