Local Time 07:33 12 Nov 2026 Privacy Policy
Forum Index : Windmills : New Bearings for F&P
KarlJ
Posted: 06:10am 17 Jan 2010
Has anyone sourced new bearings for their F&P, are there better types available?
Dimensions are
OD 1.848" = 46.9392mm
ID 0.982" =24.9428
Appears the factory ones are a sealed ball bearing unit,
I just read a sh*t load on bearing and now totally bamboozled.
I ask because I have a few bearing housings with stuffed bearings and If i'm going to buy them I sure as hell not paying $10 each from our mates in NZ.
Posted: 06:53am 17 Jan 2010
I just purchased new bearings through CBC a local bearing supplier last time at about $6.00 each i think.
I am pretty sure they are a standard size metric bearing and are cheaper than imperial bearings.
You can flick the seals out if you want to lower the drag but i choose to leave them in on the outside faces and only remove the inner seals.
You can also get them with a metal dust seal (less drag) or a weather proof rubber seal (more drag)
If you can get a Japanese made bearing they are much higher quality than some other rubbish on the market.
Pete.
fillm
Posted: 07:49am 17 Jan 2010
Bearing no 6005 2rs (sealed), usually a standard size bearing stocked at bearing stores
KarlJ
Posted: 08:17am 17 Jan 2010
Glen
could you add this to the homepage in f&P bits?
KarlJ
Posted: 11:24pm 25 Jan 2010
6005 -2Z for metal seal less drag.
Found these puppies too.
http://www.vxb.com/page/bearings/PROD/Kit7674
Would they last longer? (need to be 8x longer at that price)
