Local Time 07:43 12 Nov 2026 Privacy Policy
Forum Index : Windmills : how protect windmill from high windspeed
lichong712
Posted: 03:39am 06 Jan 2010
For Homemade wind turbines, how to protect them from high wind speed? How to test the strength of the blades? especially for the PVC-made blades.
I heard many commercial wind turbines have an automatic shut down feature to prevent over-speed damage.Can this feature be homemade?
If you are intent to reduce your power bills,why not pay wind power cost?
DTV004
Posted: 07:18am 06 Jan 2010
yes the call automatic furling read the post you will see is easy to make your's too
lichong712
Posted: 10:03am 13 Jan 2010
thanks DTV004
I also want to know that How to test the strength of the blades made by pvc. How does the PVC Pipeline Thickness should be? Safty is the most important things
KarlJ
Posted: 01:02pm 13 Jan 2010
all depends on the length of the blades, I'd be thinking 2m diameter is about it for PVC blades cut from pipe
