Local Time 08:05 12 Nov 2026 Privacy Policy
Forum Index : Windmills : Where to buy Windmill Blades
mark30504
Posted: 10:08pm 09 Nov 2009
Hello
Our company is doing a project for a customer that need a windmill style blade.
We need about a 13 foot dia. blade assembly.
Where is a cost effective place to by these ?
We do not have the time to manufacture it.
Also the wind speed of our customer is quite high,
55mph
Should we be looking at a certian type of blade angle or surface area ?
thanks for any input.
mark
Posted: 10:42pm 09 Nov 2009
Hi Mark.
Need a bit more info. What is the windmill powering? Will you need a low speed high torque turbine, to pump water, or a high speed turbine for power generation.
55MPH is very fast. Is that a constant speed or peak.
Clarasonic
Posted: 09:56am 26 Nov 2009
Please research ROHACELL as a possible material for making strong \ light weight blades which can take extreme temperatures.
ROHACELL has the ability to be formed and bonded to many common materials.
More details can be found at www.Clarasonic.com
Clarasonic - Distributor of Rohacell a light weigth \ dense cell composite PMI foam which could be used for windmill blades.
www.Clarasonic.com
