Local Time 00:47 12 Nov 2026 Privacy Policy
Forum Index : Windmills : experimental blade profile
Saaremaa
Posted: 07:53am 27 May 2006
Here is a link to an interesting .pdf file on fluid dynamics.
http://www.appliedfluids.com/UUST01.pdf
It outlines the use of wavy bumps (tubercules) in the leading edge of an airfoil shape to both decrease drag and increase lift of the airfoil in a fluid.
I am guessing but since air is a fluid - the same principles might well apply. The difficulty in making a set of test blades would lie in actually cutting a number of blades with identical bumps along the leading edge.
(hint: It would take a CNC router to do it accurately)
makourain
Posted: 02:09pm 27 May 2006
[quote](hint: It would take a CNC router to do it accurately)[/quote]
what does the CNC stand for?
Posted: 10:29pm 27 May 2006
Golf balls!
They have dimples to reduce air resistance.
CNC = Computer Numeric Control.
Saaremaa
Posted: 06:49am 28 May 2006
It's not so much small dimples that matter in this case - but larger bumps or just a scalloping of the leading edge.
I think that if it gives 5% to 10% better performance - on a big blade that is a substantial difference in output over time.
here's some more on the same subject:
http://www.sciencedaily.com/releases/2004/05/040512044455.ht m
http://www.dukenews.duke.edu/2004/05/design_0504.html
