Local Time 07:18 12 Nov 2026 Privacy Policy
Forum Index : Windmills : 10 diode bridge rectifier
DeanC993
Posted: 12:57pm 05 Jul 2009
hi guys back from FLORIDA but anyhow i am working on a 10 diode bridge rectifier why 10 diodes?...because the stepper motor has 5 wires coming out of it, 2 diodes are for each wire , and amps need to be higher for 4 double a batterys i am also making it run into a capciter then discharge to an LED but the led has a good resistor
Dean Cheevers
Posted: 03:18am 06 Jul 2009
Hi Dean
Could you grab a multimeter and measure the resistance between the 5 leads? It sounds like it would be a 5 wire stepper with the center connections commoned, like on this page...
http://www.thebackshed.com/windmill/assemblyMini3.asp
If there is one wire with a equal resistance to the other 4, then thats the center tap and you can leave it unused.
DeanC993
Posted: 12:32pm 06 Jul 2009
thanks what dail is used to measure Resistance on a multimeter?
Dean Cheevers
Posted: 01:11pm 06 Jul 2009
Hi Dean
Ohms. Lower value means less resistance.
On the Links page http://www.thebackshed.com/windmill/Links.asp
are a few links to electronics for beginners sites, these are a good place to start with using multimeters.
DeanC993
Posted: 09:27pm 06 Jul 2009
thanks Gizmo
Dean Cheevers
