Local Time 00:02 12 Nov 2026 Privacy Policy
Forum Index : Windmills : problems whit my touch panel and  GUI CALIBRATE
tenij000
Posted: 02:15pm 02 Jul 2025
ili9341 display
t_irq gp7
t_do
t_din
t_cs gp5
t_clk
PicoMite MMBasic RP2040 Edition V6.00.02RC26
OPTION COLOURCODE ON
OPTION CPUSPEED (KHz) 200000
OPTION LCDPANEL ILI9341, LANDSCAPE,GP15,GP14,GP13,GP20
OPTION TOUCH GP5,GP7
if do GUI CALIBRATE
press first cross left side then press second cross right side then error
> GUI CALIBRATE
Error : Touch hardware failure 4095,4095,4095,4095
Posted: 10:47pm 02 Jul 2025
You don't appear to have connected the SPI touch pins. These are shared with the display and SD card System SPI.
t_irq gp7
t_do = MISO - GP16
t_din = MOSI - GP19
t_cs gp5
t_clk = SPI_CK - GP18
If that isn't the problem try directly entering either of these touch settings from two of my panels:-
GUI CALIBRATE 0, 128, 194, 872, 630
GUI CALIBRATE 0, 180, 202, 870, 638
Then do GUI TEST TOUCH to check the accuracy, as those values may not be accurate for yours. If they are too far out experiment with slightly different values to get closer.
Some panels have the touch foil reversed so require different settings like this:-
GUI CALIBRATE 0, 3956, 3841, -876, -647
If GUI TEST TOUCH draws lines at the wrong end of the screen use those settings.
PS To ensure your posts go on Microcontrollers rather than Windmills go to Forum Index : Microcontroller and PC projects rather than Active Topics.
Edited 2025-07-03 11:39 by phil99
