Local Time 00:02 12 Nov 2026 Privacy Policy
Forum Index : Windmills : programming MX250
palcal
Posted: 09:47am 03 Oct 2024
I have a project that uses an MX250 and I need to load the hex file. I have a PicKit3 but always have trouble using it. I'm fairly sure this wont work but if I put the MX250 in a 170 backpack can I program it with the PicProg gui like I do with the 170 chip.
Posted: 12:05pm 03 Oct 2024
They are in the same family so it should work.
I have successfully programmed a couple of MX270 chips (one for Geoff's ASCII terminal and the other for the USB console version of MMBasic) using pic32prog.exe via an MM2 and TassyJim's MMflash windows front end.
It can also use an Arduino Nano. The MMflash.zip on his site has all the info.
