Forum Index : Windmills : anemometer cups
Haxby
Posted: 12:36pm 16 Apr 2009
I know you can make your own anemometer cups but I am after a store bought unit just like the one from otherpower.com
Problem is the otherpower ones are $20 plus $30 shipping in USD so it would be close to $80 AUD
Is there a local Australian option for the cups?
Posted: 12:49pm 16 Apr 2009
I made my little one from ping pong balls. Buggers to cut in half!
Next time you go grocery shopping look at the cooking untensiles. 3 soup ladles would work, or if you want to go big, try 3 woks
Posted: 02:10pm 16 Apr 2009
I made mine from the top rounded end of plastic towball covers. Not too hard to cut off accurately in the lathe after inserting a wood plug to stop the chuck squashing the plastic.
These things seem to last and last, anemometer has been going for over 20 years now, black plastic cups, unpainted.
Dinges
Posted: 02:20pm 16 Apr 2009
AU$ 27.50 cheap enough ?
This one turned up after some quick googling for the search terms 'anemometer davis replacement parts wind cups australia':
http://www.davisinstruments.com.au/products/other_items/7903 L_windcups_large.html
http://www.davisinstruments.com.au/price_list.html
I suggest you google yourself a bit more, as the above hit was the first one I checked; there are likely better deals out there.
Peter.Edited by Dinges 2009-04-18
Bernie the Bolt
Posted: 02:31pm 16 Apr 2009
Not sure if you have this product in AUS - vanish stain remover for clothes washing. Sold in a bright neo pink canister contains measure which is a half sphere.
Bernie the Bolt
I'd rather be sailing!
