Local Time 06:43 12 Nov 2026 Privacy Policy
Forum Index : Windmills : Resistance on windmill
caesius
Posted: 05:08pm 24 Mar 2009
Right, I've gone and build a turbine following the exact plans on this site. It's sitting in my vice and apart from the blades, tower and electronics it is complete. Just for fun I hooked up some wire from the stator, through three bridge rectifiers and measured the voltages I got.
It looks like there's sufficent volts at low rpm but one thing is bothering me; when I short out the two wires there is a lot of resistance all of a sudden on the rotor - is this the resistance that the blades will have to overcome? Because I find it hard to believe ANY sized blades would be able to turn that...
Posted: 07:46pm 24 Mar 2009
This is good. This is the brake mode. A battery is not like a short to the windmill.
Gordon.
Posted: 11:57pm 24 Mar 2009
Gordons right, a battery load is not like a short circuit.
In simple terms, as the windmill speeds up from standstill, its output voltage is less than the battery voltage, so the windmill is unloaded and free to spin up faster.
Once it is spinning fast enough to reach battery voltage, the battery starts to take a charge, current is flowing and the windmill then starts to feel a load.
So it looks like your windmill is working perfectly, you just need a battery to test it properly.
