Local Time 00:12 12 Nov 2026 Privacy Policy
Forum Index : Windmills : TL084
irishron40
Posted: 08:54pm 24 Oct 2023
hi Can someone tell me the correct way to test a TL084 with a multi meter.
I wanna rule out a faulty one.
thank you.  ron
irishron40
Posted: 09:18pm 24 Oct 2023
am I correct in saying this?
using the ohm function for testing  a TL084cn on my multi meter
pin 1 and pin 14 should have reading either way
pin 2 and pin 13 should not have reading either way
pin 3 and pin 12 should have reading either way
pin 4 and pin 11 should not have reading either way
pin 5 and pin 10  should not have reading either way
pin 6 and pin 9  should not have reading either way
pin 7 and pin 8 should have reading either way
ron
Posted: 09:32pm 24 Oct 2023
For a breadboard test of any op-amp connect one input to a voltage divider (2 x 10k resistors in series to V+ ang Gnd.). The other input is connected to the wiper of a pot (10k to 100k) with the outer legs to V+ ang Gnd.
As you turn the pot slowly from one end to the other the op-amp output should abruptly switch from high to low or vice-versa as you pass through the mid point.
In-circuit testing depends on what the circuit is. Post a circuit diagram and description of what it is supposed to do.
Edit
The breadboard test needs to be done for each of the 4 op-amps in the package.
Edited 2023-10-25 07:43 by phil99
irishron40
Posted: 09:48pm 24 Oct 2023
this is the  charge controller circuit
its not switching the relay when adjusting the pots on the circuit board  so I suspect the tl084 to be faulty
https://www.thebackshed.com/windmill/articles/TL084-Controller.asp
ron
Posted: 11:34pm 24 Oct 2023
Voltages to record.
Output of regulator should be 8V +/- 0.4
With the battery supply set to 13.9V pins 3 and 6 should be about 3.3V
Adjust Low-V pot for the same voltage at the wiper as pin 6 then measure pin 7 while turning the pot back and forth a little either side of that spot. It should switch between 0V and 8V as you do that.
Adjust High-V pot for the same voltage at the wiper as pin 3 then measure pin 1 while turning the pot back and forth a little. It should switch between 0V and 8V as you do that.
Pin 13 should be 4V.
Adjust Low-V pot for 0V at pin 9 and adjust High-V pot for 8V at pin 10, the Dump-On LED should light and pins 12 and 14 should be 8V.
The transistor should have 0.6V on the base and 0.2V on the collector and the relay should now be on.
Edited 2023-10-25 10:13 by phil99
Posted: 03:41am 25 Oct 2023
Multi-meter resistance measurements that you should get in circuit +/-10%. (no power)
IC Pins      Result
6 - 3        0 ohms
7 - 9        0 ohms
8 - 12       0 ohms
3 - 11       3.3k - Black lead to 11 (Bat. negative)
6 - 11       3.3k
10 - 11      100k
8 - 11       110k
12 - 11      110k
13 - 11      4.6k
14 - 11      3.2k
5 - 11       8k to 18k varies with Low-V pot
3 - 11       8k to 18k varies with High-V pot
1 - 10       0.6V  Diode range, Red to 1 Black to 10
Edited 2023-10-25 22:27 by phil99
irishron40
Posted: 07:24am 26 Oct 2023
thank you all . some advise I can work with.   thx
