Local Time 06:43 12 Nov 2026 Privacy Policy
Forum Index : Windmills : Romanian Windmill Prototype
vasi
Posted: 01:21pm 16 Mar 2009
I saw at a TV show this Windmill Prototype:
More pics here.
Update:
You can see the movie here. The story starts at 2:54 min., after commercials (first, it speaks about few foreign little inventions and how much money inventors gained and then, about romanian inventions and how little or no money romanian inventors gained. Then, is about windmill and after that, is about another romanian inventor, Justin Capra). The windmill starts at 0.5m/s wind speed and is compared with an AirX windmill...
Is worth watching entire movie.
Edited by vasi 2009-03-18
Elvish name: Mablung Miriel
Beyound Arduino Lang
Posted: 10:05pm 16 Mar 2009
This alternator is close to identical looking to a 1kW chinese type, which is probably a design from somewhere else anyway.
Comparing to an Air-X. These are quite small windmills.
Gordon.
CraziestOzzy
Posted: 10:50pm 16 Mar 2009
The perfect blade for trend setters...unusual share
http://cr4.globalspec.com/member?u=25757
http://www.instructables.com/member/OzzyRoo/
KiwiJohn
Posted: 02:33am 17 Mar 2009
That look interesting Vasi!
May I ask what was your experience with the F&P pieces?
Best regards
vasi
Posted: 12:25pm 17 Mar 2009
  GWatPE said   This alternator is close to identical looking to a 1kW chinese type, which is probably a design from somewhere else anyway.
Gordon.
Yes, the propeller is mounted on a 1KW Chinese turbine for testing purposes. And yes, the target are small windmills, for starting in the smallest wind speed possible, more adapted to our country conditions.
Posted: 06:49am 23 Mar 2009
Repost of missing posts
vasi wrote.....
  KiwiJohn said   That look interesting Vasi!
Best regards
Hi John,
The project stalled for long time because of family problems. Recently, I had the possibility to acquire a solar panel and a battery. Now, I finished mounting the solar panel and connected the battery and controler. I'm ready to connect the windmill but .. is not ready .
The 60 type stator is prepared as Glenn staggered stator connections, 5 poles in series and 3 poles series x 3. I will use original hub for a wile. I have the pipes for pillar, the all rectifiers (4 pieces for one stator) and no cable for connecting at controller yet. I hope this week to start making the blades (5 or 6 blades, 1.2m - depends on what material I can find on wood store). Not touched yet the 100 type stator, will wait until first one is up and running (but I will configure it as 6 pole series and 4 in series x 2).
I hope soon starting to post on my windmill tread.
Best regards
Vasi
KiwiJohn wrote.....
Thanks Vasi, I look forward to reading of your projects.
