Forum Index : Windmills : wind generater
guitarbaby
Posted: 11:17pm 07 Mar 2009
hello would anyone know i am hooking up a wind generater i am using a prestowind generater it and it will charge a bank of batteries so i have the rectifier buy the batteries but when i hook to batteries it is like there is a dead short and blows the 35 amp fuse this is before i even have it hooked to the generater i am sure the positive is connected to the right place i am baffled thanks
niall1
Posted: 12:33am 08 Mar 2009
hi guitarbaby
what kind of rectifier ,fuse are you using ? did it come with the generator ...single or three phase ?
if its a standard bridge type rectifier make sure its plus goes to plus on the batt and its negative goes to negative on the batt ,these should be clearly marked on the rectifier... (otherwise it,d could definately short )
if the rectifier is working ok ,the battery shouldnt even know its there
Edited by niall1 2009-03-09
niall
CraziestOzzy
Posted: 12:43am 08 Mar 2009
without knowing much about the actual setup (pics), I would suggest hooking the batteries up without rectifier and see if fuse shorts...should not short. Check continuity direction of your rectifier to see if any hidden internal problem before reconnecting it to batteries (as you may have already buggered it up) and then wire correctly batteries to rectifier and see what happens. If fuse shorts, get another rectifier or make your own out of some diodes...basic methodology of fault finding may help...it's often the simple things that get me
http://cr4.globalspec.com/member?u=25757
http://www.instructables.com/member/OzzyRoo/
niall1
Posted: 12:57am 08 Mar 2009
craziestozzy
very true ...strickly personally speaking ..if i had a euro (1.9775 AUD then ) for everything i hook up that doesent work i,d be ri.... mumble mumble    Edited by niall1 2009-03-09
niall
Posted: 01:28am 08 Mar 2009
I have just looked at the specs for the presto generators. The output figures are for open circuit voltage and short circuit current for a particular rpm. This is very misleading, as they quote the power output as the product of these results. This can never be.
These units seem to have internal rectifiers or external, depending on the model. It is just a matter of connecting - to battery - and + to battery +, after the rectifiers, with the fuse in somewhere between.
You need to post a photo, etc, to show what you have done.
Gordon.Edited by GWatPE 2009-03-09
guitarbaby
Posted: 07:33pm 08 Mar 2009
thanks gordon i got it to work i am charging 2 12 volt batteries and am running a 1000 watt inverter i had a 100 watt light going and then used the skisaw for a bit and it discharged baterys so i put wind mill bake into the wind and the batteries charged back up right away so i am just waiting for a charge controller so i can leave every thing hooked up i will report back thanks again
