Local Time 00:12 12 Nov 2026 Privacy Policy
Forum Index : Windmills : ChatGPT Lotto Program
Glen0
Posted: 11:34pm 25 Feb 2023
Someone had to do it.
Typed the following question into ChatGPT:
"write a program in mmbasic to create an array with integers 1 to 40 and then to select six of them, removing them from the array when they are selected, then print the six numbers"
REM Create an array with integers 1 to 40
DIM nums(40)
FOR i = 1 TO 40
 nums(i) = i
NEXT
REM Select six numbers
DIM selected(6)
FOR i = 1 TO 6
 REM Pick a random index from the remaining numbers
 index = INT(RND * (40 - i + 1)) + i - 1
 REM Add the selected number to the output array
 selected(i) = nums(index)
 REM Remove the selected number from the input array
 FOR j = index TO 39
   nums(j) = nums(j + 1)
 NEXT
NEXT
REM Print the selected numbers
PRINT "Selected numbers:"
FOR i = 1 TO 6
 PRINT selected(i)
NEXT
This program first creates an array called nums with integers 1 to 40 using a FOR loop. Then, it selects six random numbers from the nums array by repeatedly picking a random index from the remaining numbers, adding the selected number to the selected array, and removing the selected number from the nums array using another FOR loop.
Finally, the program prints the selected numbers using another FOR loop and a PRINT statement.
These are the results I got.
AUTOSAVE
Upload completed 1
Saved 586 bytes
Time taken: 1765mS
RUN
Selected numbers:
27
20
25
24
17
14
Feel free to use these numbers next week.
