Local Time 00:13 12 Nov 2026 Privacy Policy
Forum Index : Windmills : Need help with Telnet activation under Win10
Frank N. Furter
Posted: 12:40pm 16 Feb 2023
First: I have NEVER worked with Telnet.
- I have WLAN enabled (can see the neighbor's network).
- Under Windows Features I have enabled Telnet
- Raspberry Pico W was flashed with "2023-02-15_193513_PicoMiteWebV5.07.07a16" and
 "OPTION TELNET CONSOLE ON" was executed
- Raspberry Pico W hangs on separate power supply and flashes
- When I enter "telnet 192.168.1.111" in the console, I get the error message:
 "Could not connect to host, on port 23: connection error"
Also when I start TeraTerm (with the INI from Peter) I get the error message: "Connection timed out".
What am I doing wrong???
THANKS!
Frank
SORRY - WRONG FORUM!!! - this should be in the "Microcontrollers and PC projects" forum
Edited 2023-02-16 22:48 by Frank N. Furter
