Local Time 06:13 12 Nov 2026 Privacy Policy
Forum Index : Windmills : Wiring for Savonius?
Mr.Sleepy
Posted: 11:55pm 28 Jan 2009
Hi guys...what would be the best wiring configuration for my Savonius VAWT?...the two F&Ps are 42 pole each and the rpm range I normally get is 60-300rpm, but averaging mostly around 100-180rpm...Cheers, Russell.
Posted: 12:07am 29 Jan 2009
Hi Russell
How big is the savonius? Is it the one in your avatar picture?
Mr.Sleepy
Posted: 01:09am 29 Jan 2009
Hi Glenn, yes it is...I hope to lessen the cogging by slightly offsetting the mounting of the two F&Ps but I may need to reconfigure their wiring first to suit the rpms I get...I saw that the standard factory wiring for the 36 pole units was somewhat applicable to VAWTs but I have 42 pole units...I'm not sure exactly whether I'll use a 12 or 24VDC system yet, but that shouldn't matter too much regarding the wiring should it?...Russell
Mr.Sleepy
Posted: 01:10am 29 Jan 2009
oh!...and they are 3 sets of 44 gallon drums cut in half
Posted: 01:34am 29 Jan 2009
Hi Russell
Do you know what F&P type you have, there are 3 different wire sizes in the 42 pole range. This page might help...
http://www.thebackshed.com/windmill/WhatFP.asp
With a savonius the cogging isnt a problem when it comes to starting in light wind, they have more than enough torque to get going with a standard F&P. The only problem you may have is noise, I had a F&P on a Lenz VAWT and it was very noisy until I decogged it. If the windmill isn't too close to your home, I wouldn't worry about it.
Mr.Sleepy
Posted: 03:19am 29 Jan 2009
they're 80 series (0.8mm wire)
Posted: 10:11am 29 Jan 2009
An 80 series should be fine for 24 volt use in good winds, 12v use in light winds. You wont need to modify it at all, just connect a 3 phase rectifier to the F&P output leads, real easy.
You should have enough power there to drive two F&P's
Mr.Sleepy
Posted: 11:32am 29 Jan 2009
Excellent, thanks Glenn...are 3 phase rectifiers usually incorporated in regulators?...would you recommend anything in particular or have any info?...cost is typically an issue, but i prefer reliability...thanks, Russell
Posted: 11:56am 29 Jan 2009
Have you got an old car alternator lying around?
http://www.thebackshed.com/windmill/articles/AlternatorRect. asp
Mr.Sleepy
Posted: 12:28pm 29 Jan 2009
Will I need 6 of them?...one for each output wire from the 2 F&Ps?
Posted: 12:31pm 29 Jan 2009
2, each one has 3 inputs.
Mr.Sleepy
Posted: 12:51pm 29 Jan 2009
Ok...and no, I don't have any alternators lying around...is there a schematic or list which shows what I need to safely and efficiently charge batteries with my windgen?
Bucaneer
Posted: 03:08pm 03 Feb 2009
Hello Glenn and Russell
I'm new in this forum.
I'm looking to attach the stator to a vertical turbine, but the axis shall be fix. How you interconnects the stator to the unit and the rotor to the blades.
Thanks Nomar
The future will be off the grid.
Mr.Sleepy
Posted: 08:39pm 03 Feb 2009
Hi Nomar,
I have a 1:3 pulley configuration at the top of the VAWT being driven by the blades. I have turned and threaded an adaptor to connect the shaft to the pulley and also allow removal of the shaft if I need to later for any maintenance or change the pulley belt. I'm using the whole F&P shaft with a motor at each end and fixing the stators to the VAWT frame via a bracket. There are probably better ways but it's what I have to work with. I will post some pics (or I could send them via email?), which may clarify things, as soon as I get some batteries for my camera.
Cheers, Russell.
