Local Time 06:03 12 Nov 2026 Privacy Policy
Forum Index : Windmills : It lives
wind friend
Posted: 06:02am 19 Jan 2009
After lots stuffing around and some learning steps it's up, and have seen 20 A in to 13 volts. Axial flux, 20 magnets on each plate. 15 coils wired 3 Phase delta 1.5 ohms resistance phase to phase. coils encased in a resin and the magnets are only 8mm apart. Cuts in at 60 rpm, some chinese blades and as the addict said it's more fun than watching solar cells. New mount that allows cable to run down centre of mast rather than wrapping arond mast. And an off topic question if I may. Does anyone know what is required to weld directly from batteries?
Wind Freind
KiwiJohn
Posted: 06:31am 19 Jan 2009
Sorry, I dont know the answer to your welding question but on the other hand I cant imagine a better site to ask the question! I am sure an answer will be along real soon!
Greenbelt
Posted: 06:49am 19 Jan 2009
Hi
Thats great! I'm new on this home grown power site and I have been watching in silence off and on for a couple of months. I see many things here that interest me. a lot to learn and some things to share.
About the Battery Welding, you will need (3) 12 volt batteries connected in series Good heavy wire Leads # 4
An electrode holder or clamp, a ground clamp heavy gloves
and a arc welders helmet don't settle for a cutting torch
mask. Good luck.
Oh! I've never welded this way but I am a fair welder ( a part of my job ) You control the current
by raising or lowering the welding rod, Distance to the
work
Posted: 02:21pm 19 Jan 2009
Here are all your battery welding questions answered:
http://www.lcool.org/technical/80_series/bat_weld/battery_we lding.html
have fun
SparWeb
Posted: 07:59pm 19 Jan 2009
Tinker's link didn't work because a "space" got dropped in, probably just by accident:
Hmmm... doesn't preview properly when I try it either...
Steven T. Fahey
SparWeb
Posted: 08:01pm 19 Jan 2009
... but when it's posted, the link works. There is still a space in the text title of the link, but the HTML code works okay. Before posting, there was no space in either text or HTML. Weird...
Steven T. Fahey
wind friend
Posted: 11:16pm 19 Jan 2009
To all who replied re welding question many thanx.
wind freind
ps iv'e seen a bigger hammer used to make stuff fit.
