Forum Index : Windmills : generator
DaViD
Posted: 05:51pm 13 Jan 2009
Can a gas powered generator be used for wind power?
If your not living on the edge your taking up to much space!
KiwiJohn
Posted: 08:34pm 13 Jan 2009
Probably not, at least not easily. The gas powered generator is likely built for much higher RPM than you could get with wind power unless you incorporated a gearing stage.
DaViD
Posted: 08:37pm 13 Jan 2009
Thans i dont know much about wind power as u can tell
