Local Time 00:22 12 Nov 2026 Privacy Policy
Forum Index : Windmills : Very simple furling design needed
tommydog
Posted: 08:05am 04 Apr 2022
When I say simple, I don’t have a workshop and have very limited tools (I have a cordless drill, jigsaw, screwdrivers, sockets, circular saw).  I will be making a turbine in my living room. Due to the simplicity of the below design, I was thinking of making something like this:
https://greenterrafirma.com/DIY_Wind_Turbine.html#variations
The problem is the above does not have a safety furling mechanism and I live in an area with very high winds.  As I want something very simple to make, I am looking for simple furling designs.  I saw the below design on instructables and wonder what people think:
Maybe as an alternative, I could look at horizontal furling, where the generator and blades are mounted off to the side of the yaw bearing and the tail is placed on the other side of the tower.  The tail could have a hinge and a spring (similar to the springs in the photo above but in a horizontal position) either side so that it yields in strong winds.  As an alternative idea, what about using something like an old beam torque wrench to mount the tail to?  That way by picking an appropriate range of wrench, the tail would start to yield in high winds.  Not sure what people think of these ideas?  I need some very simple designs that I can make in my living room.
Technophiliac
Posted: 11:11am 04 Apr 2022
Check out the IstaBreeze® Heli and Windsafe models for some inspiration.... There are clips on Youtube showing them working... they appear to work well in gusts....
Davo, Wellington. You can have it perfect, on time, and at the best price. Choose any two.
tommydog
Posted: 12:28pm 04 Apr 2022
  Technophiliac said  Check out the IstaBreeze® Heli and Windsafe models for some inspiration.... There are clips on Youtube showing them working... they appear to work well in gusts....
Thanks for that information.  This appears to show the mechanism below.  It looks a nice design, but I need ideas as to how I would construct something like that without access to a welder.
