Forum Index : Windmills : Jaycar mill - 300 - 500 W???
domwild
Posted: 09:04am 11 Nov 2008
Claims in Jaycar flier:
300 W unit starts in 2.5 m/s wind, 300 W at 12 m/s and 500 W at 15 m/s. As the spare props cost only $69.95 for three I checked the cat. no. MG-4534 item:
Three blades with 1.5 m dia (not radius!), material ABS.
Cost of unit: $599, no mast, mounting hardware or guide wires. But contains charge controller in head and slip rings. Total weight: 17 kg.
Can one get 500 W from a 1.5 m dia prop in 15 m/s wind? I doubt it and I am too lazy to put that into the formula!
Any comments?
Cheers,
Winston Churchill
oztules
Posted: 09:40am 11 Nov 2008
With only half reasonable blades .... 15m/s will give you over 1kw at the shaft to play with at 1.5 meters diam.
........oztules
Posted: 11:09am 11 Nov 2008
Hi Dom,
for most places where people live, 30knot wind gusts come around a couple of times a year. I know of a few places where people have built homes that 30knots is common, but the wind does become tiring. Above 20knots, loose tin on a roof starts to play tunes. The rating of a windmill to 15m/s is usually just to inflate the numbers, and only indicates late furling to me. This is probably why they throw blades and bearings. I have a 300W chinese controller on my F&P mill that seems to handle the 600W. The electrical brake does make some noise until the mill stops. 700W has been recorded from a 300W chinese windmill into a 24V battery. The guy said that the machine got a little busy at that power level, was very noisy as well, swish-swish.
I think that with a better set of blades, and some attention to bearings and weather seals, and lightening of the tail, that the chinese units could be OK.
Gordon.
