Forum Index : Windmills : alternator or generator?
mick97
Posted: 12:52pm 09 Nov 2008
My name is Scott,and i just joined the forum.
Im interested in building a wind generator windmill.
I had astarting question.
Do I use analternator?Not a generator correct?
Anyadvise on what type of car i can get thisout of,or does it matter?
As long asit is a alternator?
Just getting started here,so have a fewQs.. ha.
I couldn't find asection on this to learn from.Is there apost somewheres to study?
Thanks a million,
Scotty
scott
KiwiJohn
Posted: 05:34pm 09 Nov 2008
Hi Scott and welcome.
You could use an alternator from a car but few, if any, of the forum members do that. To be effective the alternator needs to spin at very high RPM compared to the speed of the wind turbine which of course requires you to use one or two stages of gearing. Gearing is both awkward to build and introduces losses so most home wind turbine builders prefer to use direct drive.
Several forum members use washing machine motors of the kind that are really huge steppers and although plentiful in NZ and Australia may not be so easy to find in the US. The brands are Fisher and Paykel, LG and now (I believe) GM. You can use a small stepper motor for experimenting which will light a few LEDs.
Another popular thing to use is a low voltage permanent magnet DC motor, old treadmill motors seem to be popular.
If you find a DC motor or big stepper you can make a simple test by joining all wires together and if this makes the motor hard to turn by hand you have a likely candidate.
There are a few sites that describe making alternators from wood, resin, wire, magnets etc and I understand some of these designs are quite efficient. I dont know if any forum members use one of these.
mick97
Posted: 08:49pm 09 Nov 2008
Thanks John,
Sounds like a lot of work..lol
I do believe my mom hasan old treadmill.
Will have to check on that one.
Finding awasher brand name will be hard i would think,but can call some appliance stores on that one,for old machines.
Any other advise would be grand.
Scotty
scott
Posted: 08:36am 10 Nov 2008
Hi Scotty.
I agree with John, see if you can find a treadmill motor, they are perfect for your first windmill. I was at my local tip ( dump, recycling center ) last week and there were several electric treadmills for only a few dollars each, I was tempted to check them out for a good motor but ran out of time. Looks for treamills where the belt is broken, it usually means the motor was ok and it was thrown out because the belt let go.
mick97
Posted: 12:49pm 10 Nov 2008
Hey,
Thanks Glenn,
That would be a good place to start then by the sound of it.
Good tip on the broken belt.I would of never thought of that..teehee
Scotty
scott
