Local Time 05:23 12 Nov 2026 Privacy Policy
Forum Index : Windmills : pressure vs. velocity
stevet47
Posted: 09:04pm 23 Sep 2008
I know they are hard to distinguish when just thinking about the wind, but what is more important for a wind turbine, the velocity of the wind, or wind's pressure.
I suppose this would vary based on the type of design, IE, a drag-based design like a savonuis would probably benefit from pressure, but a lift-type turbine would probably benefit from velocity.
Has anyone actually researched this?
AllanS
Posted: 09:14pm 23 Sep 2008
The pressure is caused by the air's change of momentum, which is directly related to its velocity. Unless your windmill is on the top of a mountain where the air is thin, wind velocity is all that matters.
But of course, I might be wrong...
stevet47
Posted: 01:48am 24 Sep 2008
Thanks AllanS
Anyone else have any input on this?
I am working on a wind turbine with an enclosure around it, and need to
figure out whether the closure should increase velocity or pressure.
Jarbar
Posted: 02:42am 24 Sep 2008
Hello,can you describe your idea and to which type of mill you are refering to VAWT or HAWT.
Jarbar.
stevet47
Posted: 12:33pm 24 Sep 2008
Well, I've got a couple of things going, one is multi-directional, so it work work that same as either a VAWT or a HAWT.
The other is a HAWT.
Now that I think about it, I am kind of answering my own question... I suppose of a lift-type design, air pressure doesn't matter, as it is the speed that the air passes the blades that creates the lift and turn the rotor.
But for a drag-type, I am less sure. High velocity is still necessary in order to turn it with usable speed, but I think it would require more pressure to actually turn it, and for the reverse side to push through the wind.
I'm just thinking out loud I guess.Edited by stevet47 2008-09-25
SparWeb
Posted: 02:59pm 24 Sep 2008
Air pressure isn't directly relevant. Air density is very important. Doing some research, you can find the equation for power collected by a wind turbine. One of the first variables in the formula is air density.
Any wind turbine blades tested at sea level will collect only 90% of the power when installed in an area at 3000 feet altitude (or 1000 meters). I live at 3200 feet altitude, so I experience this effect in all sorts of ways; boiling water, fuel economy of my car, and power through my windmill's rotor blades.
I can't do much about where I live, so I don't have control over the local air density. The site of the wind turbine can have a strong impact on the wind speed it receives, so ultimately, the wind speed is the only thing you have any control over.
Steven T. Fahey
