Local Time 05:23 12 Nov 2026 Privacy Policy
Forum Index : Windmills : savonius gap ratio
mechamz
Posted: 05:07am 17 Sep 2008
there is a support beam in the centre of the turbine blades, and the diameter is 2cm. the bucket gap width is 6cm, the diameter of turbine is 44cm, and the height of the turbine blade is 80cm.
when calculating the "gap width ratio, s/d", do I need to take the diameter of the support beam into consideration?
so my gap width ratio = (bucket gap width,s - diameter of support beam) / diameter of turbine ??
or just ignore the diameter of the support beam?
thanks
looking for low rpm alternator
I'm looking for an alternator(low rpm) pm me please
Gill
Posted: 09:30am 17 Sep 2008
G'day mechamz,
I recall this information is redily available on sites that appear near the start of Googles response to a search on 'savonious'. I don't have the site bookmarked so would need to find it again. It's easy to find so I won't do it as I feel something that easy and basic is your job.
Happy hunting.
Cheers Gill _Cairns, FNQ
mechamz
Posted: 02:02pm 17 Sep 2008
  Gill said   G'day mechamz,
Happy hunting.
Thanks. I have did a lot of research on that..
But I'm wondering do I need to consider the diameter of the beam??
grub
Posted: 09:28pm 17 Sep 2008
I remember reading that the overlap is 29% but the support tube needs to be accounted for (added to the overlap). The person who reached the 29% did so by setting his rotor up on a vehicle and driving at a set speed, then adjusted the gap and retested. Not sure where I found this info but it stuck in my memory.
Posted: 11:18pm 17 Sep 2008
I do think the beam diameter needs to be taken into account. There is a lot of air that wants to move through that gap, so any obstacle will reduce the designs efficiency.
I would try to use the smallest diameter beam I could, or get rid of it all together. Could you use 4 smaller beams, one at each edge of each shell?
windlight
Posted: 11:51pm 17 Sep 2008
The beam represents an orifice to the air flow, as the air encounters the beam the air is compressed and the velocity increases, as the air leaves it expands and slows.
As with any orofice it does presesnt as a restriction but without doing the maths I would guess you need to allow 10% of the beam diamiter.
A link if it works, not straightforward but....
http:http://www.trident.on.ca/orifice-air-
allanEdited by windlight 2008-09-19
mechamz
Posted: 03:43pm 18 Sep 2008
  windlight said   The beam represents an orifice to the air flow, as the air encounters the beam the air is compressed and the velocity increases, as the air leaves it expands and slows.
allan
the link is not working
windlight
Posted: 10:53am 19 Sep 2008
OK google "air flow through orifice", you will have to multiply the information up to your dimensions but it will give you an idea.
allan
Jarbar
Posted: 09:03am 20 Sep 2008
Mechamz,
This site may shed some light as well.
http://www.aeromech.usyd.edu.au/aero/introvisc/node6.html#no de9
Jarbar
