Local Time 05:11 12 Nov 2026 Privacy Policy
Forum Index : Windmills : Stator Winding Question
Wes Lemarr
Posted: 06:15pm 12 Sep 2008
Good Day All
I have seen people in China hand winding stators & they were working with 4 strands of copper wire, winding all four strands simultaneously on one pole, I assume the reason for doing this is to save time & labor? The result is four separate windings on one pole, which are then gathered & soldered to gather. I am wondering if is as effective as using one strand of wire with four times as many turns & how it effects the performance of the stator?
Thanks for any advice.
Wes LeMarr
oztules
Posted: 09:02pm 12 Sep 2008
It is the same as winding with twice the diameter wire at the same turns. ... Wes:"I am wondering if is as effective as using one strand of wire with four times as many turns & how it effects the performance of the stator?"... same number of turns Wes.... not 4 times.
1/2 the diameter, so a=pi r x r... means there is four times the copper in 1" than 1/2 inch. (2 squared)
The only difference is packing factor is slightly better for 4 in hand, eddy currents will be less of a problem with 4 in hand, and it is easier to bend 4 of the 1/2 diameter wire by hand than a single thicker strand... same with the tension to keep it tamed.
I used 1.8mm wire for my stator, which was managed with difficulty, it would have been much easier to use 4 in hand .9mm wire.... same length/turns.
If using for high frequency, then skin penetration is better with 4 in hand than single wire.
..........oztules
Wes Lemarr
Posted: 12:01am 13 Sep 2008
OK, I understand your explanation makes it clear.
Thanks Again
