Local Time 05:23 12 Nov 2026 Privacy Policy
Forum Index : Windmills : 24 volt scooter moter rated 100 watts?
feix62k
Posted: 03:43am 06 Sep 2008
24 volt steper moter from kids scooter rated 2400 rpm 100 watts at 6amps just made 3 blades mounted them on a alloy plate 2 screws in each blade, 2feet long each, took it out the front just now and it was kicking butt almost to hard to hang on to the moter, next will have to test mount it and measure amps ect Im excited any clues or commentscheers felix6ampsEdited by feix62k 2008-09-07
dont the days seem lank and long when nothing gos right and everthing gos wrong
feix62k
Posted: 03:44am 06 Sep 2008
man I need to check spelling
windlight
Posted: 04:16am 06 Sep 2008
Firstly you can edit your own post.
Is it geared like those from Oatley? Because it's hard to see you getting over 600rpm and therefore 6volts if it's direct.
allan
Posted: 07:08am 06 Sep 2008
  feix62k said  took it out the front just now and it was kicking but almost to hard to hang on to the moter
Hi felix,
are you saying that the motor had no external load during this test.
Be careful holding by hand, as the blades can easily swing around and chop chop whatever is in the way.
Gordon.
feix62k
Posted: 08:20am 06 Sep 2008
yeh no load other then an ameter or test light the light was starting to glow at least I have some power this time . not sure how to read this multi meter it was more likely to have been 1.2 watts not 4 as it kept flucktuating prob .3 .4 .5 .6 ect the back thrust just about pushed me over .
Yes I wont try that again Safety is the number one priorityEdited by feix62k 2008-09-07
feix62k
Posted: 08:27am 06 Sep 2008
I think the 3 blade tapered config was better then the six blade straight just a bit noisier caught the wind instantly.
feix62k
Posted: 11:24am 08 Sep 2008
did a controlled test with multimeter and battery drill got up to 1.5 volts at about 200rpm drill was a bit flat its somthing I guess beter then my alternater o amps .I am going to use mounting bracket of scooter steering head bearings ect waste not want not its all scrap from the tip cost nothing but my time . any idea of tail shaft length as blades are 4 foot .thanks again felix
feix62k
Posted: 11:25am 08 Sep 2008
still cant upload my pics either faulty or takes forever
Posted: 12:28pm 08 Sep 2008
Hi feix,
your photos are too big. Crunch them to a smaller jPEG[<100k] and retry. The How To is in the FAQ on this site.
Gordon.Edited by GWatPE 2008-09-09
feix62k
Posted: 08:18am 09 Sep 2008
I give up to hard basket keeps asking for http adress dont understand never mind, its still a great forum
Posted: 02:18am 10 Sep 2008
You might be clicking on the wrong image upload button. This is the correct one to use...
Let me know if that helped.
frank133
Posted: 07:52pm 14 Sep 2008
  feix62k said   24 volt steper moter from kids scooter rated 2400 rpm 100 watts at 6amps just made 3 blades mounted them on a alloy plate 2 screws in each blade, 2feet long each, took it out the front just now and it was kicking butt almost to hard to hang on to the moter, next will have to test mount it and measure amps ect Im excited any clues or commentscheers felix6amps
Hi feix62k [I hate you] only joking dude,But I have spent over a week making blades that don't work,
My brain is in meltdown with, root, tip. angle of attack
leading edge ,trailing,
the only thing that turns is the tail I made,maybe if I made tails instead of blades and joined them to the motor,[maybe not] I am not even waiting for a windy day ,I have been blowing wind at the blades with a compressor,
If you cant post a photo,would it be possible to tell me,
the length of the blade,its 2 foot okay. if in pvc pipe,
the radius of the root and the tip,and what size pipe you used.
I think people on this site will be getting fed up with my blade questions,I have tried a number of combinations
one blade reversed,I taped two blades together like a aeroplane prop,even tried them upside down.
I have cut about fifteen blades up to date.ain't this fun.I am still trying,
three blades at 2 foot long is what I am looking for,cheers frank
Jarbar
Posted: 09:38pm 14 Sep 2008
Hello Frank,this link may help,but then maybe you've already seen it.I found it informative.
http://www.youtube.com/watch?v=aHB4zxWd3Ls
Anthony
Jarbar
Posted: 09:49pm 14 Sep 2008
Oh and part 2 with the blade construction.
http://www.youtube.com/watch?v=K0YxYDnmaO0&feature=related
Anthony.
Jarbar
Posted: 09:53pm 14 Sep 2008
And still no blades sorry I forgot it was a three part series.
http://www.youtube.com/watch?v=s75-lCKKK8g&feature=related
Anthony.
feix62k
Posted: 08:04am 15 Sep 2008
Hi Frank if you (send me your email) I will send you some pics direct, as I cant figure this site to send stuff. the blades are 2 feet long base is 3 inch wide tapering down to 1 and 3/4inch. I just bolted the flat edge to the mounting plate slightly angled the tip back about 1 inch and did the usual rounding of edges not rocket science more good luck then managment,just make sure they are all turned the same way and try to keep them all the same shape and weight (balanced). the other windmill I built has 6 blades 2 foot long just 4 inches wide no taper they work fine as well. pvc pipe just over 4 inch diameter .ok
Posted: 09:17am 15 Sep 2008
4" dia pipe seems pretty small to make a decent blade from!
Gordon.
feix62k
Posted: 10:39am 15 Sep 2008
iT COULD BE A BIT BIGGER I MEASURED ACROSS THE PIPE THEY WORK WELL FOR ME.I GUESS IF YOU WERE BUILDING A FISHER AND PAYKAL TYPE MILL YES THEY WOULD BE SMALL
mister406
Posted: 11:47pm 19 Sep 2008
Hello, I also have been looking at those motors and I wonder if they put out enough juice to charge several 6 volt batteries wired together. Please let us know the statistics as you get them jerry
jerry
