Local Time 05:10 12 Nov 2026 Privacy Policy
Forum Index : Windmills : Motors...Am I correct about this?
Glipski
Posted: 11:34am 05 Sep 2008
Trying to figure this out...
If I had a permanent magnet DC motor that was 180VDC, 1700rpm...then at a usable output from a mill, I'd have maybe 45vdc@425rpms, and 22.5vdc@212rpms...correct?
Am I on the right track with this line of thought?
Posted: 12:54pm 05 Sep 2008
Yes.
The max current will not change, but the power output will be down by the reduced voltage ratio.
Gordon.
