Forum Index : Windmills : AMETEK 30V wonderfull motor for turbine
humbertini900
Posted: 08:09pm 02 Oct 2019
Hi fellas
I had a message about my ametek 30v and the build and let me see if i can answer it as best as i can.
AMETEK a while back were like golddust everyone wanted one because they were solid built and put out alot of amps with little rotational speed, so of I went and bought one from America and decided to break a swivel chair as usual for the frame of the turbine and within days my ametek arrived, I machined a collet and a hub for it and placed PVC pipes on it below is a video of me mounting the tail .https://youtu.be/OGx6k4qDBOg
I loved the performance of it but after a few weeks one of the blades broke one of my neighbours used his football and broke it in half, being a carpenter and joiner i though let me make my own blades out of wood and i felt in love with the process and loved the outcome https://youtu.be/RvC2mDBVJcg here is another video of the wooden blades in action https://youtu.be/OGx6k4qDBOg .
Again because of it being a DC motor you will require a diode in line otherwise it will spin the motor as soon as you touch the batteries with the cables, just a safety precaution, good luck with your projects
Humbertini900
