Local Time 04:53 12 Nov 2026 Privacy Policy
Forum Index : Windmills : Simple VAWT
Sambo
Posted: 11:07am 22 Jul 2008
Hey guys,
new to this. I built a small VAWT out of plastic pipe, a broomhandle and 2 rubbish bins. Thought you might be interested.
I wanted something cheap, that didnt need metalwork, and worked in imperial as well as metric units. Let me know what you think. I'm also hoping the combination of wood and plastic will cut down transfer of noise from the generator to the mill.
Hopefully someone else can use the design.
Cheers,
Sam.
http://www.instructables.com/id/Build-your-own-Savonius-VAWT -Vertical-Axis-Wind-T/ http://www.instructables.com/id/Build-your-own-Savonius-VAWT -Vertical-Axis-Wind-T/
Gill
Posted: 10:31am 28 Jul 2008
Good first effort Sam.
As you say on the last pic, you'll need to find a generator to match the power potential. Forget the F&P, something much smaller will be less likely to stall it. Now you've done the easy stuff and made a mobile, the real work begins with making it produce power.
Good luck with your project.
Cheers Gill _Cairns, FNQ
