Forum Index : Windmills : towers
BBDrums
Posted: 06:03pm 02 Jul 2008
Is it possiable to build tower sections like the big boys do , radio towers?
If I took electrical conduit and welded them together would it work? Just wondering.
ME drummer. I like to hit things ;)
Robb
Posted: 04:23am 03 Jul 2008
If your going to put anything of substance on top of it something stronger would be advisable.
BBDrums
Posted: 12:42pm 03 Jul 2008
  Robb said   If your going to put anything of substance on top of it something stronger would be advisable.
Even with guy wires?
Robb
Posted: 05:07am 04 Jul 2008
  BBDrums said   Is it possiable to build tower sections like the big boys do , radio towers?
Electrical conduit in this part of the world is not that robust at all. Normaly PVC plastic but in the old days rolled steel with an unwelded seam.
Whats it like over there? Material, diameter, wall thinknes etc.
BBDrums
Posted: 05:52am 04 Jul 2008
you can get it at Home Depot 1" 1.5"etc... (sorry don't know the conversion)
It's aluminum or metal. THe stuff electicians use on industrial jobs, the ones that lead to a junction box. Not that expensive.
http://www.alliedtube.com/electrical-raceways/conduit/emt.as pEdited by BBDrums 2008-07-05
fillm
Posted: 09:17am 04 Jul 2008
Hi BB ,
Steel elect conduit is very thin walled , you would have to be an experienced welder with a good mig ( for steel ) tig ( aluminum ) or you will be blowing holes in it every time you arked up ,also it would need to be built with mulitudes of triangular braces as well as stay wires . In my opinion spend the money and buy heavy wall 3" pipe or similar... Phill...
BBDrums
Posted: 12:18pm 04 Jul 2008
  fillm said   Hi BB ,
Gotcha!
