Local Time 04:42 12 Nov 2026 Privacy Policy
Forum Index : Windmills : alternator for low rpm
mechamz
Posted: 07:37am 29 Jun 2008
Is there any alternator for low rpm vertical axis wind turbine? the rpm the around 160rpm.
any suggestions? thanks
I'm looking for an alternator(low rpm) pm me please
johnj
Posted: 12:23pm 29 Jun 2008
My suggestion is to take a small pm generator off a moped/scooter. You might need some sort of voltage regulation. But if you use the power generated for heat, (run it through some bulbs) you might be ok with just the gen?
cheers, J
robbo
Posted: 12:28pm 29 Jun 2008
Possibly best bet is to go a standard 100series F&p, as these "put out" at really low revs. Generaly only do about 1-2 amps at low wind speeds, But if you can get it to turn all day ...
The highest I saw on mine was 4-6 amps at higher revs (HAWT), but cut in at 12 volt, really early.
You will have to decogg it for a VAWT.
Edited by robbo 2008-06-30
"the Earth was not given to us, by our fathers, rather, it is lent to us by our children".
mechamz
Posted: 02:44pm 29 Jun 2008
  robbo said   Possibly best bet is to go a standard 100series F&p, as these "put out" at really low revs. Generaly only do about 1-2 amps at low wind speeds, But if you can get it to turn all day ...
may I know what is 100series F&p?
KiwiJohn
Posted: 06:57pm 29 Jun 2008
F&P refers to Fisher and Paykel who are makers of home applicances including washing machines, initially in New Zealand their products are also sold in Australia and the USA.
The model of washing machine is any "Smart Drive" of which there are a few variations though all will do the job as a low speed alternator the 100 series may be best. The part you want is of course the motor which is in the form of a rather large pancake shaped stepper motor.
These machines have been on the market long enough that the machines are appearing on the rubbish piles.
Everything you need to know about the various models, mounting the motor, modifying for approriate voltage (easy) etc is available somewhere on this site though you may have to look around a bit.
Posted: 09:08pm 29 Jun 2008
  KiwiJohn said   though you may have to look around a bit.
Are you saying my sites disorganised!!?
robbo
Posted: 02:22am 30 Jun 2008
As organised as my underwear drawer ! No truly, no problems with the website. Cant keep myself off of it.
(To my wifes detriment)
Good to see the "KiwiJohn" is the first to point out that F and P are a New Zealand firm!
Go John!.
KiwiJohn
Posted: 04:21am 30 Jun 2008
[quote="Gizmo"]Are you saying my sites disorganised!!? [/quote] Not at all! There is so much good stuff reading it all is not a 5 minute exercise!
dwyer
Posted: 05:19am 30 Jun 2008
However F&P are no longer manufacture in New Zealand they have gone aboard to south- east Asia country same in Brisbane Australia stopped manufacture F&P couple months ago
dwyer
KiwiJohn
Posted: 08:10am 30 Jun 2008
I believe you are right dwyer though I hope the locally made ones will still turn up at the side of the road for some time yet!
dwyer
Posted: 11:06am 30 Jun 2008
hi kiwiJohn
Yes and what ashame F&P pack up their suitcase and go find where they get their white good manufacture overseas cheaper. Dont worried l dont buy any for F&P item as all end up in the rubbish dump quicker than what anyone could buy . for sample l found one at local tip only 9 months old with bash up with an axe so someone got mad because for some reason is eletronic componet fail is mostly to blames
dwyer
