Local Time 04:32 12 Nov 2026 Privacy Policy
Forum Index : Windmills : motor advice needed for beginner
JW1111
Posted: 02:08am 19 Jun 2008
I have built a couple of Ametek 38 mills that are flying fine. I get 1 amp in 20mph for 24vdc after diode loss and 500 feet line loss. I would like to find something that delivers a little more power. I dont have the time, knowledge, or wherewithall to build motors. I found a furnace blower motor that is rated as follows:
115vac
1725 rpm
6 amps
60hz
I would like to use it to charge 24 volt. So far in 12 mph winds I am not seeing much in the way of power. Is this a reasonably good motor and can I expect much out of it in better wind? My winds average 14mph. Thank you.
Posted: 05:47am 19 Jun 2008
Sounds like a 3/4hp sqirrel cage AC induction motor. This is not very useful as an alternator without significant modification. eg mods for permanent magnets. Gordon.
JW1111
Posted: 11:57pm 19 Jun 2008
Thank you. It is nice to find a board were people are actually friendly and eager to help instead of just cutting you down on an ego trip like some of the american boards.
vawtman
Posted: 12:44am 20 Jun 2008
Seems like the same reply i gave you.Thanks Gordon for confirming.
The wonderfull world of the web.
Mark
JW1111
Posted: 01:44am 23 Jun 2008
I didnt get your reply VM, maybe it disappeared, but thank you.
