Local Time 04:22 12 Nov 2026 Privacy Policy
Forum Index : Windmills : Angle of attack
CB365
Posted: 05:05am 27 May 2008
I have finally got around to getting a set of the chinese blades to try out.
From experience can someone let me know what the best angle of attack is to suit these blades.
CB365
Gill
Posted: 11:15am 27 May 2008
G'day CB365,
Angle of attack is often around 4 or 5 degrees. But for mine, I reasoned because the angle of attack gets progressively larger towards the root because there is no blade twist, I reduced it to 2 degrees. This makes for a blade angle at the tip (and all the way along their length) of about 7 degrees.
I'm happy with the result.
Cheers Gill _Cairns, FNQ
CB365
Posted: 11:39pm 27 May 2008
Thanks Gill. I will give 7deg a try.
Chris
