Local Time 06:01 21 Sep 2026 Privacy Policy
Forum Index : Windmills : Blade Balancing
suitep123
Posted: 02:30pm 05 May 2008
Hi all:
We're new here, we have posted and received good information from the discussion boards on another website.
Can anyone point us in the right direction on how to balance the blades for a new setup? We're trying to get motor mounts and furling set up today if possible. With the ranch, it'll take longer than that I'm sure.
More questions to follow
Thank you,
Bob and Pauline
Posted: 09:09pm 05 May 2008
Try this link
http://www.thebackshed.com/Windmill/articles/TurbineBalance. asp
suitep123
Posted: 04:00am 06 May 2008
Ahhhh - thank you so much. We had actually seen that somewhere along the way, but had forgotten it was there. Even if we had remembered, we probably wouldn't have known where to find it again!
Thank you,
Bob and Pauline
Posted: 08:32am 06 May 2008
Yeah its a good page that, thanks to Gill and Klaus. The methode is very simple and dead accurate.
I used to mount my windmill in a vise and spin the turbine around to find the heavy side. The problem was as I started to build turbines over 6 foot diameter I found the vise was too low and the blades hit the floor. So I tilted the windmill back, but this made ballancing even harder.
