Local Time 00:03 12 Nov 2026 Privacy Policy
Forum Index : PCB Manufacturing : Pi-backpack
led-bloon
Posted: 10:42am 23 May 2017
Any volunteers for an ILI9341 backpack for the RaspberryPi.
A SIMPLE board with some headers for the Pi, the display/touch
AND the SD card slot (maybe SPI & I2C connections too?).
The 2.8" display fits nicely over the standard sized Pi although
insulation needed at the USB connector cans.
The SD card for removal of log/data files on-the-fly.
I've got DEX but too exhausting - overpowering - even for something
this simple!
Miss you George
Posted: 09:09pm 23 May 2017
Doesn't the Pi-cromite use the Pi's own SD card slot for access to programs?
I could whip up something in a day or five. I think that the 2.8" LCD is a good choice.
I will look into this a little more, if no-one else has plans to do the same thing.
led-bloon
Posted: 12:39am 24 May 2017
The display SD card for removal/changing of log/data/picture files while the
unit is running.
However, as you say, any of these types of files could be written/read off the
Pi SD card using ftp or other unix file transfers I guess, as long as you have
network access!
The pcb should probably have mounting/spacer holes for the Pi zero (W) board
as well as the full size Pi.
Access to SPI, I2C & other spare GPIO an advantage.
Thood for fought?
don
Miss you George
Posted: 03:20am 24 May 2017
Critical thing to know at this point, is if the Pi-cromite actually even supports an SD card as you would find on the LCD module. I expect that matherp wrote the Pi version of MMBASIC to ONLY look at the Pi's SD card, is what I am getting at.
Peter - if you are reading this, perhaps you could clarify please. I need to do a little refresher on the Pi version of MMBASIC to find out.
EDIT: I have just read through all 18 pages of the Pi-cromite thread, but nowhere in that thread, does matherp mention support of a 2nd SD card, so I therefore fully expect that the only SD card supported, is the on on the PI.Edited by Grogster 2017-05-25
led-bloon
Posted: 06:42am 24 May 2017
OK, fair enough. One last thought.
Being SPI driven, the full SD card support could be added.
It's easier to add code later, a bit trickier adding traces
to pins later though.
Miss you George
Posted: 03:14am 25 May 2017
You have a point. An excellent point, actually. I will see if I can rustle something up soon, and will incorporate the SD card on the LCD, but the CS pin is an unknown, so you would have to add a small wire jumper later - if this was ever supported.
led-bloon
Posted: 12:06am 26 May 2017
You actually will need 3 x CS, Reset, D/E & T_IRQ all of which are user
programmable. I think you just assign 6 pins yourself (pick a number)
and just run with that! You obviously would not pick pins 3,5,7 as
they are I2C and Peter has assigned certain other pins for functions,
so will have to check these out first. The Backlight I would run with a
fixed resister or a pot.
Miss you George
led-bloon
Posted: 11:42am 26 May 2017
Have scanned all of Peter's threads for the Pi-cromite and have
come up with the following pin list as documented:
SPI : Pins 19, 21, 23
I2C : Any pins can be used! User configurable (3 & 5 pi default pins).
SETPIN CIN, PIN, and FIN : pins 11,13,15 & 16
PWM or SERVO : Any pin can be used!
Pin 12 is the hardware PWM (1Hz - 25MHz)
All other pins based on a 1uS clock so frequencies will be exact
divisors of 1,000,000.
More info for PWM & SERVO at:
http://www.thebackshed.com/forum/forum_posts.asp?TID=9487&PN=1&TPN=6
IR Send/Receive : Pin 16 for receive. Any pin can be used for transmit!
COM1 : Tx pin 8, Rx pin 10
COM2 : Tx pin 7, Rx pin 11
Displays supported:
ILI9341 (320x240), ILI9163 (128x128), ST7735 (128x160) & ILI9481 (480x320)
ILI9341:
Display using SPI (CS, D/C & Reset configurable)
Touch using SPI (CS & IRQ configurable)
SD card using SPI (CS configurable)
SSD1963:
RD (optional transparent text & BLIT) user configurable
WR pin 32
RS pin 13
RESET pin 31
DAT1 pin 35
DAT2 pin 38
DAT3 pin 40
DAT4 pin 15
DAT5 pin 16
DAT6 pin 18
DAT7 pin 22
DAT8 pin 37
Information for anyone interested
edit: Correction one pin deleted from listEdited by led-bloon 2017-06-10
Miss you George
Phil23
Posted: 11:20am 10 Jun 2017
  led-bloon said   Any volunteers for an ILI9341 backpack for the RaspberryPi.
Sounds pretty minimal, but not is my list of doables; ZERO PCB design experience.
Have you considered Routaboard or Perfy ?
Both have some software to play about with & ATM I'm looking at adding an IO board to the CGM2 MM+.
Actually have some Perfy on hand, lightning fast delivery, but at the time we ordered It I didn't realise there was a double sided variant of Routaboard.
It looks very flexible with 2 horizontal trace tracs per pin on the reverse side.
Phil.
Posted: 05:40pm 10 Jun 2017
This is on my to-do pile, but things have been busy lately. I will have a go at this soon. The compiled list led-bloon did above is very useful, and will save me a whole heap of thread reading, so that helps.
Posted: 11:11pm 10 Jun 2017
I've been playing with this idea a little tonight. I have designed a Pi-zero and a standard PI footprint, and have been playing with these along with LCD footprints.
The standard PI might need to be dropped on this backpack board idea. The PI-Zero fits beautifully with a 2.8" SPI LCD, on a board of the same size as the 2.8" LCD.
The standard-size PI is too big to fit as a piggy-back arrangement with any LCD smaller then 4" or so.
The Pi-Zero is a perfect match though, as it is small and SO CHEAP, that this makes it the most logical choice - for SPI LCD's. The PI-Zero and a 2.8" SPI LCD give you a complete system with touch and advanced GUI controls for fifteen bucks or so, which is very impressive. So, at this stage, I am dropping off the standard-size PI footprint, and the piggy-back board will concentrate on the PI-zero module.
I am designing for either a 2.8" LCD with ILI9341, or a 3.2" LCD with SSD1963 - you can use either type on the same board(but not together).
EDIT: Seems there is no 3.2" SSD1963 LCD - all the 3.2's seem to be SPI with the 40-pin header - but they are still on the SPI port with the SD card. I will design the board to suit the 2.8" LCD directly, but able to be plugged onto any standard SSD1963 parallel interface TFT, that way, you can pick and choose, but it keeps the PCB small, which keeps the cost down.Edited by Grogster 2017-06-12
Posted: 11:29pm 11 Jun 2017
Well, here you go led-bloon:
Will that do?
EDIT - Forgot to mention:
SPI LCD D/C = Pin 29
SPI LCD RST = Pin 31 (same as 1963)
TOUCH CS = Pin 26
TOUCH IRQ = Pin 24
SD CS = Pin 33
1963 RD = Pin 36
H/W PWM = Pin 12
All other pins are as already stated. You can use either a 2.8" SPI LCD with touch, or ANY supported SSD1963 LCD with SPI touch and SD card. For the latter, you don't fit the SPI LCD, and instead plug the PI-zero board directly onto the pin-header on the 1963 LCD module of choice. You would need some self-adhesive PCB supports for the arse-end of the PI-zero board, to stop it flapping around on the LCD header, but that is dead-easy to do.Edited by Grogster 2017-06-13
Posted: 11:57pm 12 Jun 2017
Hi All,
Initially I thought "what a great idea" but on consideration there are a myriad of readily available Pi Displays and I see Peter M has a display going already.. Would it not be better to wait until Peter provides some native support for these other displays?
I admit I am a NOOBSy here.. but it seems to be an unnecessary addition and makes a 3 stack arrangement.
Kind Regards,
led-bloon
Posted: 12:43am 14 Jun 2017
@Grogs very nice .. but does it come in red?
@Mick - all I can say is that the displays are relatively cheap (ILI9341
& SSD1963) and the code is written for them .. sounds pretty good to me.
@Matherp - BIG thanks
Miss you George
Posted: 01:05am 14 Jun 2017
Hi Led-bloon, All,
Whilst the ILI9341 are relatively cheap you also have to factor in the price of the adapter board and connectors and components, then the fact is it adds an extra 12mm to 20mm at least to the height due to a 3 level stack.. is it worth doing?
I don't want to sway you away from this project, I instead prefer to think that I am offering an opportunity to take a closer look at your design idea before you commit to a production run..
If After all you want to go down that path, great.. I may even buy one. But I think it isn't an ideal outcome, especially due to the added height... you need female/male headers between the Pi and adapter AND between adapter and display, although you could direct solder to the display..
Posted: 03:10am 14 Jun 2017
You have exactly the same arrangement on the E100 boards, if you use ANY click module - a three PCB stack consisting of the LCD, the E100, and the Click module.
I don't see that as any big deal, frankly. That's just me though. Obviously you Aussies have a hard time with stacking stuff up - we kiwi's are much better at stacking then you guys seem to feel comfortable with....
Also, remember that the LCD's you can get for the PI, take up the whole damn GPIO port header, and it is difficult or impossible to get extra connections on to the unused GPIO pins once you plug one of those LCD displays onto the PI.
Hell, the PI-zero is so bloody cheap, there is no reason why you could not permanently mount the PI on the backpack board, so it essentially becomes permanent, dropping you back down to a two-board stack - or 2.5 board stack, if you want to look at it that way...
@ led-bloon - default is green, but YES they could be ordered in red!
led-bloon
Posted: 02:18pm 14 Jun 2017
Just checking the pins in use now .. would like to see any
pins not connected going to a row of vias for future connection
(possibly at the bottom of the board?)
Also, any room for a "click" board adapter area?
Miss you George
led-bloon
Posted: 02:43pm 14 Jun 2017
@Grogs
You have directly connected the CS of both LCDs to ground.
The SPI LCDs should use an output pin from the pi for CS
(not sure if SSD LCD should have a separate CS too)
Otherwise it will clash when selecting touch/SD card or anything
else on the SPI bus
Edit: My bad - NO unconnected pinsEdited by led-bloon 2017-06-16
Miss you George
Posted: 03:23pm 14 Jun 2017
You are correct about the SPI LCD CS - My mistake - will fix. 1963 LCD CS is grounded, as you will always be using that LCD if it is installed at all, but I made a boo-boo with the SPI LCD CS.
I don't think there is room for a Click socket - I will look and see, but the entire bottom edge of the PI module has to be kept clear for connectors on the PI module, so you can't put anything there, which pretty much.....
led-bloon
Posted: 07:20pm 14 Jun 2017
Grogs
The SPI Header at the top of the board is pretty much wasted
as it has no CS output. Could I suggest increase header to
5 pins & using COM2 TxD doubling up as offboard SPI CS?
At least COM2 RxD could still be used for logging on a serial
line say.
I would probably mount the Pi Zero between the PCB and
the SPI LCD display (albeit upside down) and soldered in, with
adequate spacing for connectors.
I think too much to ask for a re-design or second version.
Using SPI LCD additional (spare) GPIO pins are available at the
SSD LCD header .
SSD LCD there are no spares available, but COM2/PWM/I2C can be
re-deployed.
Miss you George
