Forum Index : PCB Manufacturing : tinning the PCB tracks
| Tinker Guru Joined: 07/11/2007 Location: AustraliaPosts: 1904 |
Many years ago I came across a tinning solution in a bottle. This was just wiped over the tracks of an etched board, tinning the tracks and preventing oxidization. Is that stuff still available? What is it called so I can search for it? I normally use PCB laquer on my simple boards but now have made one where I need to connect (screw on) something to the tracks. Thanks. Klaus |
bigmik![]() Guru Joined: 20/06/2011 Location: AustraliaPosts: 2984 |
Hi Klaus, Liquid Tin But it is not cheap. Kind Regards, Mick Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
| brucedownunder2 Guru Joined: 14/09/2005 Location: AustraliaPosts: 1548 |
I,ve used a tinning paste many years ago . worked magic on copper pipe and any copper or brass surface,just steel wool (stainless) the surface area ,heat with either propane torch or similar and wipe it off with a clean rag for perfect coating. used it every day at work on copper air pipes . You can tell if it's good --the small tin of the stuff is heavy. Bruce Bushboy |
Thanks guys, good tips. I did some more googling on the subject and found a kind of metal bristle brush that fitted into a soldering iron. Loading that with solder and flux paste coat the tracks apparently is the cat's meouw on tinning tracks - but its expensive (to me). So, rummaging in my odds & ends box I found small a brass cleaning brush (works a bit like a lip stick - you twist one end and the bristles come out the other). So I'm modifying this, just pull out the bristle bundle and fit them into a copper 3/8" pipe which suits my old Weller soldering iron. I think it should work, I'll let you know. Klaus |
| greybeard Senior Member Joined: 04/01/2010 Location: AustraliaPosts: 184 |
If it's only a small area that needs to be tinned and the rest can be covered with pcb lacquer then use a 'pre-loved' piece of soderwick. Just hit it with some solder then apply it over the track to be tinned. It will leave a neat thin coating of solder on the pcb. |
