Forum Index : PCB Manufacturing : 44 Pin MX170?
| Phil23 Guru Joined: 27/03/2016 Location: AustraliaPosts: 1667 |
Why so little interest in utilising this chip in designs? I get that the 64 pin is way superior, but it's a much more complex layout. Although the 28 pin is great, you loose out big on pins once any type of display & the com port is put to use. Would a 44 pin layout work where ILI9341's were connected by a length of flat ribbon? Phil. |
Grogster![]() Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10104 |
I think it is PROBABLY simply a case of "If I am going to move to the 44-pin one, I might as well use the 64-pin one, as they are pretty much the same price but I get all these extra I/O pins, more memory, more speed etc." I could do an "Explore-44" type of module if you thought it would be useful. I would need to run that name past Geoff for his approval though, but that would keep the names all similar. WhiteWizzard did produce a similar module based on the 44 chip a while back, and I seem to recall that matherp and others also did boards featuring that chip. I don't think I ever did any experimenters version of a board using the 44, although I did use the 44 in designs specific to my requirements. A 44 pin module could be setup to specifically include an SPI output header, to allow simple connecting of a 14-pin connector for the SPI LCD's with touch, then you could just use a 14-way DuPont linking cable which would make it less of a rat's nest when it came to wiring up the LCD, if that is what you are getting at. I think though, that if you are using one of those "Explore" series of modules, they are really designed for you to tinker around with, and once you perfect your design, you can make a special PCB to do your design, or just a host board that the Explore series module can plug into to form the heart of the project. Is an Explore-44 kind of module something people would like? EDIT: Perhaps an E100-style arrangement with the 44 board being the same size as a suitably common SPI LCD module, and you bolt them together in a sandwich as you do the E100? That would give you a smaller version of the E100, without quite the same feature set, but still with an LCD and touch, and plenty of I/O pins. Much smaller too, so cheaper in terms of LCD and board etc. I quite like that idea...... Smoke makes things work. When the smoke gets out, it stops! |
You can get carrier boards that convert the 44pin chip into a DIL which goes happily with veroboard. That's way I go when I want a few more IO pins to play with. I usually solder the Vcap directly onto thee carrier and tie the ground pins together. Jim VK7JH MMedit |
I will have a play with this idea. I think that the 2.4" LCD with touch is the sweet-spot price-wise, at only about US$10 a unit. 2.8" ones can be had, but they are a few dollars more for the tiny extra LCD space gained, so I don't think they are worth it. 2.4" SPI LCD's on eBay Smoke makes things work. When the smoke gets out, it stops! |
Hmmm, I've been paying $7 to $8AUD for the 2.8" ones I've bought over the past 6 months. Our dollars only getting in the 70c range lately. This is what I see on ebay's AU search. Edit:- Probably not hard to fit a 2.4 screen to a 2.8" board, but a bit more difficult the other way round. Might see if I can fins dimensions for both. |
These are some 2.8" ones I have found: 2.8" SPI LCD The $8 or $9 ones you linked to seem to be ones without any touch. I think if it was to be done at all, it should be made to support the LCD with the touch ability. You don't have to use it if you don't want. It costs about US$3 or so more for the 2.8" vs 2.4" and seeing as this extra three bucks only gains you 10mm of screen size - what are your thoughts on that? 2.4" and 2.8" are both easy enough to come by from what I can see, although the 2.4" one does seem to be quicker to find. I might grab a couple of the 2.8" ones to play with. EDIT: I have ordered a couple of the 2.8" ones to play with. I don't have a footprint for these, so will have to wait till they get here then attack them with my callipers. I have footprints for the 2.2" and 2.4" LCD's. You are probably right about being able to fit a 2.4" LCD to a 2.8" carrier board, although I have never tried that. Smoke makes things work. When the smoke gets out, it stops! |
