Local Time 00:02 12 Nov 2026 Privacy Policy
Forum Index : PCB Manufacturing : Trouble loading .net 4
smudge
Posted: 03:36am 30 Jun 2016
Hi I've bought Autotrax and I've loaded in into Windows 7 (64). It's a genuine registered copy and is running under bootcamp on a Mac. When it asks for .net i download it successfully then it just sits there trying to instal and gets no further. Anyone else had this problem and found a solution?
Smudge
belsean21
Posted: 02:03am 19 Jul 2016
Not familiar with Macs or bootcamp. However, this may help.
Unified .NET Framework Troubleshooting Guide
Updated: what to do if other .NET Framework setup troubleshooting steps do not help
Try the Microsoft .NET Framework Repair Tool
If that doesn't work you may need to use the .NET Framework Cleanup Tool & reinstall .NET from scratch
.NET Framework Cleanup Tool User’s Guide
Sean.
Posted: 08:46pm 19 Jul 2016
Hi Smudge,
As I dont have any MACs to play around with I cannot help directly.
Have you tried the AutoTRAX forum
http://www.forum.kov.com/
If you are not a member PM me with an email address and I can send you an invite.. You should get a response to your problem, usually within 24hrs.
I am sure someone else has had the same problem as you.
Kind Regards,
