Local Time 00:03 12 Nov 2026 Privacy Policy
Forum Index : PCB Manufacturing : Autotrax DEX Q & A
Posted: 02:19am 13 May 2016
Hi all,
I know there are quite a few members of TBS using DEX,
Whilst the main forum for DEX support is forum.kov.com I would like to open up this thread for people to ask questions and provide answers to others as well.
I also see that we can share parts that we have created with each other here as well.
Whilst I do not profess to be an expert I have been using DEX for a while and am prepared to help if I can.
I also wish to create a PCB from start to finish and try to show here how to go about doing so.
plover
Posted: 03:23am 13 May 2016
bigmick
I did buy a copy of DEX at the favorable price. I am coming from Protel some 10 years ago when I started bailing out making my own circuits as hobby. The board production was the main factor too costly in time and money.
DEX however kindled my interest to a degree, now have installed it on a laptop that suddenly was available for a few weeks with sacrificial Win 7 32 bit. I have managed to open the program and be suitably overwhelmed with the number of Icons.
Having viewed a few of the videos available I am sold, but also aware of the time needed to come up to speed and efficiency.
As a simple circuit I have in mind (one I made many years ago very rudimentary but a pcb) Analogue Devices AD591 two legged temperature sensor, 1 microAmp per degree K.
Needs 272 mV offset to start at 0 deg C and then the aim was 10 mV per degree C going to the Digital Multimeter to read out in deg C, ie 1V would be 100 deg C.
Input connection, normal header pins?
Output connection to DVM, banan metal parts to fit the DVM spacing ?
Somehow a 9 V battery might be involved or coincell??
As the device produces 1 microA per /deg C a resistor combination to trim to the 273 mV at 0 deg/C
Then a few resistors (trimpot perhaps) to get the 273 mW reference off set.
Well just to kick off the start, I can however see there may be many more deserving examples.
I will see if I can manage a schematic, I did play with placing a few symbols and draw lines, probably the schematic I can just about manage over the weekend. Edited by plover 2016-05-14
Posted: 03:31am 13 May 2016
Hi Plover,
Do you have a schematic/pictures of anything? It could be of interest..
As the Banana Jacks are not a standard part I can go through the process of creating one and possibly adding a 3D image from one of the 3D download sites available.
Hmm..
Kind Regards,
EDIT ***
I would rather not have this thread cluttered with design suggestions, it makes it difficult for someone to locate something they are looking for.. Please use PM or the thread I started in the microcontroller forum
Micro Forum Thread
Kind Regards,
MickEdited by bigmik 2016-05-14
