Local Time 23:53 11 Nov 2026 Privacy Policy
Forum Index : PCB Manufacturing : Are there any packages that will import an eagle 5.9 board ?
zeitfest
Posted: 12:04pm 04 Jun 2024
Are there any PCB design packages that will import an eagle 5.9 board ?
I used to use eagle 5.9 for boards (without eagle schematics) so ...
AFAIK Fusion 360 will only use 6.0 files or later
Posted: 01:20pm 04 Jun 2024
Zeitfest,
If you can send me the file I can try in DEX for you
DEX is supposed to be able to import Eagle files but I am not sure which version.
zeitfest
Posted: 01:59pm 05 Jun 2024
Thanks Mick,
I've asked DEX about it so will wait on events
Posted: 08:53pm 05 Jun 2024
Zeitfest,
No worries, it has an import of eagle in its menus, I have never imported an eagle project but I have imported an eagle library.
If you need any assistance to check the process let me know.
Mick (The big one)
zeitfest
Posted: 05:43am 06 Jun 2024
I asked DEX and they say  it requires the eagle XML files so that means eagle 6 and later. Curses !
Posted: 06:43am 06 Jun 2024
Hi Zeitfest,
Maybe someone on TBS has eagle v6 or later and can import it and save it as a newer version.
I think I read that eagle was now defunct but I am not sure if it can still be downloaded anywhere, maybe try it.
PhenixRising
Posted: 08:16am 07 Oct 2024
  bigmik said  Hi Zeitfest,
This just worked for me, Mick.
I downloaded "Autodesk_EAGLE_9.6.2_English_Win_64bit.exe"
It didn't run at first, just the splash screen and then it died. It's a known problem and the fix is to replace two DLLs.
Imported and re-saved an old Eagle project and it loaded straight into DEX.
Posted: 09:25pm 09 Oct 2024
Excellent Phoenix,
I am glad it worked well for you.
